t5 leaking from speedometer gear
  • Thread starter Thread starter SadbutTrue
  • Start date Start date Aug 14, 2007
SadbutTrue
2,391
Thousand Oaks, California
Aug 14, 2007
  • Aug 14, 2007
Is this common? I reused the clip that the c4 used to hold the speedometer gear in place, it works fine (or seemed to but looks like theres a steady drip of transmission fluid coming out of it). Any ideas? Just bolt it in tighter (its snug right now, didn't want to risk stripping it or anything)? Should there be any o-rings or sealant there?
Thanks
iskwezm
4,159
20
79
Rowland Heights,California
Aug 14, 2007
  • Aug 14, 2007
replace the o-ring
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Aug 14, 2007
  • Aug 14, 2007
iskwezm said:
replace the o-ring
x2 There should be an O-ring in there, and it probably needs replacing.
red65
411
Ann Arbor, MI
Aug 14, 2007
  • Aug 14, 2007
It's pretty easy to strip the threads that hold that clip in (ask me how I know), and it will do absolutely nothing to slow the leak. iskwezm and bottlefed are right - replace the o-ring; tighten the bolt carefully.
66Runt
680
Aug 14, 2007
  • Aug 14, 2007
SadbutTrue
2,391
Aug 15, 2007
  • Aug 15, 2007
where can i get a new one of these o-rings? and if necessary, what kind of grease should i use?
F
ForceFed70
4,818
BC Canada
Aug 15, 2007
  • Aug 15, 2007
You can buy o-rings at any decent hardware store.
I'd use standard wheel bearing/chassis grease.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
