T5 rebuild kit
  • Thread starter Thread starter 1991GreeNLX
  • Start date Start date Oct 19, 2004
1991GreeNLX
129
Houston TX
Oct 19, 2004
  • Oct 19, 2004
were did yall but your rebuild kit from and how much????
HISSIN50
34
129
Oct 19, 2004
  • Oct 19, 2004
many use D&D or Hanlon.
good luck.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 19, 2004
  • Oct 19, 2004
D&D kit
Hanlon video on rebuilding
1991GreeNLX
129
Houston TX
Oct 19, 2004
  • Oct 19, 2004
thanx for the help ill check it out
1991GreeNLX
129
Houston TX
Oct 19, 2004
  • Oct 19, 2004
website please
V
v8only
2,378
22
49
Oct 19, 2004
  • Oct 19, 2004
www.hanlonmotorsports.com
i paid a little over $200 with the video and an extra bearing.
9
90pony302
65
southern illinois
Oct 19, 2004
  • Oct 19, 2004
take a look at this before you decide.... http://www.5speeds.com/t5/gforce.html ....thats g-force's new t-five kit thinking of using it next time the t-5 burns up.
J
JesseR
  • Oct 19, 2004
can a novice actually take on the task of a rebuild?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 19, 2004
  • Oct 19, 2004
Absolutely, but get the video first so you can see what tools you'll need.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 19, 2004
#10
  • Oct 19, 2004
  • #10
I don't know how you feel about the DYI thing when it comes to gears, some people don't like the idea of working on transmissions. If the DYI transmission fix idea isn't something that you would rather leave to someone else, here are some resources:
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com/index2.htm for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://cartapes.com also has a video on how to rebuild your T5 or Tremec. It costs less than $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
You will also need a magnetic base and dial indicator to measure the endplay ($20-$40). http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=1290&PARTPG=NNLMK32
The tricky part is that you will need some shims to adjust the endplay in the two shafts: the new bearings will change the clearance. There is no way of telling what it will be until you get to the point that it is time to measure and check the clearances. Halon has the individual shims if you can wait for them. If you can't afford the wait, the auto parts store can sell you some shim stock and you can make your own, or have a machine shop make them for you. The shim stock comes in brass (easy to cut) and steel, in varying thicknesses. That's where the dial indicator & base come in - there is no way to get the clearance right without it.
Getting the car jacked up high enough to get the trans jack in and out from under the car was somewhat challenging. Since I didn't have a helper, getting the trans out of the car and back it was one of the more difficult things about the job. I built a trans jack out of 2x6's, some angle iron and a $25 floor jack. If I hadn't done that, I would have needed a helper or to rent a commercial trans jack. At 100+ pounds the Tremec 3550 was far too heavy for me to lift by myself.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
G
Hello everyone! New to this forum but looking forward to posting and reading posts from others. I own a 70 mustang fastback 347 crate w / T5.
  • gnorton52
  • Oct 27, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 27, 2026
General karthief
