Does anybody have a T5 WC apart and could take a couple pictures for me or perhaps answer a question from memory? This is my first T5 rebuild so I'm not sure about a couple items... if you pull up the T5 service manual page 3-7 the area in question is from item 66A through 69. When I took mine apart, the loose bearings all fell out and there was no retainer like seems to be pictured in the diagram. Then there was what I assume is the spacer, which was all torn up. There was no thrust bearing or race, and I can find no trace of them ever having been in there. I have a master overhaul kit which has a thrust bearing and race (looks like a washer). There is no spacer in the kit though unless it uses a different type than what was in there, the damaged spacer that I pulled out had a slight flange to seat into the input shaft. This stuff is always hard to describe without looking at it, so I'm going to go take a picture or two of what I'm talking about and post it up in a few minutes.
Oh, this did damage a few of the hard parts like the input shaft and a couple other things so if anybody has some spare parts laying around, let me know. The closer to Tampa you are the better.
Thanks in advance,
Brian
Thanks in advance,
Brian
