t5 stuck in neutral
  • Thread starter Thread starter 1993SSP
  • Start date Start date Nov 21, 2008
1993SSP
1,194
Ky
Nov 21, 2008
  • Nov 21, 2008
I have a project car, it has been sitting with a bad motor for about 3 months, it was left in neutral, now the tranny seems to be froze in neutral, anyone ever had this happen?? It is full of ATF, I had just changed it before it was left sitting
D
Deleted member 87397
Nov 21, 2008
  • Nov 21, 2008
Something is either gummed up from sitting for so long and needs a bit of force or your clutch is out of adjustment and not letting it go into gear.
93 LX
3,081
Norwalk, CA.
Nov 21, 2008
  • Nov 21, 2008
"Full" of ATF? It should be full it should be about half filled or filled until it starts to dribble out of the filler hole. It should move when the engine is off but you could pull the shifter to make sure its not messed up. I had my Capri sit for 10 years and the tranny worked fine after I got it fixed and back on the road.
1993SSP
1,194
Ky
Nov 21, 2008
  • Nov 21, 2008
it has the proper amount of ATF in it, I was able to get it to move a little today, had my friend who is a auto mechanic with over 30 years experience, it had him baffled as well, the damn thing was perfect before it was parked.
old_blue
1,783
282
124
Nov 22, 2008
  • Nov 22, 2008
is the motor seized? only that I can guess is the motor is seized and the clutch wont engage.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 22, 2008
  • Nov 22, 2008
Does the shifter rock side to side in nuetral?
It just won't go forward or back into gear?
This is without the engine running right?
hotcobra03
poteet,tx
Nov 22, 2008
  • Nov 22, 2008
How much play in shifter? Is it cold .try heating trans with a hot work lite
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Nov 23, 2008
  • Nov 23, 2008
kick it in there, dont be gentle with it.. Mine used to do this, Id beat it into 1st and after that it would loosen up!!
or it could be that the trans is destroyed, and physically wont shift... my t5 right now is doing this.. Thats why I have a 3550 in the mail ahahahah....
1993SSP
1,194
Ky
Nov 23, 2008
  • Nov 23, 2008
It was just seized up, warmed up today and I managed to get it free as far as front to back, shifting from side to side is still tight, the motor in it is a fresh rebuild, we will get it running towards the end of the week, it should loosen up and be fine I hope.
hotcobra03
poteet,tx
Nov 25, 2008
#10
  • Nov 25, 2008
  • #10
Cold weather glad to here that good luck with engine
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Thursday at 10:40 AM
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
