T5 transmission fluid
  • Thread starter Thread starter SportStang
  • Start date Start date Sep 2, 2008
SportStang
  • Sep 2, 2008
Ok, I was about to attach my T5 to my 302 and place it into my car. I was told it would be easier to fill the T5 with fluid before I set the engine with T5 into the engine compartment. Ok, so I started to fill the T5 and to my surprise it started to come out of the tail shaft, is this normal? I know when it is level it's fine, but I intend to attach it to the engine and drop the whole thing in. For sure it would be tilted backward and the fluid would run out. My question is should the fluid stay in, when tilted that far back or is the bearing seal nedd replaced. Thanks
stykthyn
5,232
2,652
223
gainesville
Sep 2, 2008
  • Sep 2, 2008
if you have an extra yoke you can place it in the tail shaft or I prefer to actually fill the tranny through the shifter hole after it's been installed. it makes the tranny easier for me to handle and I dont have any spots on the floor from fluid that has come out of the tail. just my .02
skunk21
1,203
Taxachusetts
Sep 2, 2008
  • Sep 2, 2008
no it's normal for any tranny to loose it fluid out the tail shaft when tilted even just a little on some, you would have to some how cap it or install and secure a yoke in there.
since the thing is out the way to do it is get a funnel and secure some hose on it that will fit in the fill hole, now feed the hose through the shifter hole from inside the car and pour the fluid into the funnel until fluid comes out of the fill hole...make sure the car is level you are done. you can use this method during regular changes just pop of the shifter bezel and lower boot and fill from inside the car go slow and to avoid a spill, never had a problem .
W
wtpLXfox
  • Sep 2, 2008
I've had my tranny in and out of my car many times and recommend just filling it through the shifter location. Like they said, go slow and use a funnel so you don't spill everywhere. Be sure to just let it sit and idle to get the fluid around all the gears and when you first drive it go through all the gears to get them well lubed. I typically do this with the car in the air though I don't recommend it as I'm typically about to piss my pants from being scared; gets the job done though.
Also, I believe the amount needed is 2.8 quarts.
SportStang
  • Sep 2, 2008
Thank you all, very helpful!!!!
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
