Tach help
  • Thread starter Thread starter mustangderek22
  • Start date Start date Aug 21, 2006
M
mustangderek22
40
New Ringgold PA
Aug 21, 2006
  • Aug 21, 2006
I just bought a Auto Meter tach and I need help on where the green wire goes?? I know the red-power, black-ground, and white-light but I`m not sure where the green one goes...Thanks
TomCat
412
Utah
Aug 21, 2006
  • Aug 21, 2006
Editing is fun!
M
mustangderek22
40
New Ringgold PA
Aug 21, 2006
  • Aug 21, 2006
No I don`t...my ignition is all stock
TomCat
412
Utah
Aug 21, 2006
  • Aug 21, 2006
Then just hook it to the (-) sideof the coil and you'll be good!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 21, 2006
  • Aug 21, 2006
the green wire with a yellow stripe on the coil harness.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 21, 2006
  • Aug 21, 2006
found this and copied it for ya
On my Tach : 4 wire hook up.
I ran the wires under the Instrument Housing that has the switches in it. I routed them towards the fuse box. After doing that I ran 2 wires through the firewall. I had to use extra wire to make them longer. Therefore I didn't hook the wires up to the tach until after I ran the wires through the firewall and connected them to their destinations. One wire went to the Negative side of the battery(right to the terminal). The other wire went to the Negative side of the ignition coil. I had to unplug the coil wire harness plug from the coil and look down inside of the socket to find the + and - signs. I then used a wire splice that was included with the tach and spliced in to the negative wire of the coil. I then hooked up the tach to these two wires.
My tach has a light in it so next I went to the Headlamp switch and removed it leaving the wires plugged into it. This can be done by looking in behind the Lamp toggle switchs. You will see two small tabs with a small screwdriver release them while gently pulling on the switches. I have driving lamps so I have two switches. One may be a dummy switch on some models. Next you use a 12 volt dc meter and locate the dimmer switch wire. I turned on the parking lamps so that the dash lights would be on hooked up my meter and turned the dimmer switch while watching the readings. I tested each wire on the back of the headlamp switch until I found the wire that had voltage go up and down with the dimmer switch. This was the one I spliced into to supply power to the light. That way it could be dimmed.
Last I connected the 12 volt power supply to the tach. I tapped into a fuse that turned off and on with the ignition key. You will want to check the fuse sockets one side is hot and turns off and the other side will be dead connect to the dead side so if the tach shorted it will blow the fuse and lose power. Always do this last for your own protection! After all other wires are connected and taped. Double check all connections! Make sure you did everything correct then start the car. Your new tach should work great.
This is intended to give you an Ideal of what to do. Always refer to instructions included with your New Tach.
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
