Hey, I'am going to put in a 5'' Autometer tach on the passanger side of the drivers side dash board. Anyways, I have an aftermarket coil (MSD Blaster) I think and was told NOT to install the tach wire into an aftermarket coil for some reason, this true? Said it would burn the tach out quick. So were do I install the tach wire then? Also I would like the tach light to be able to dim using the dimmer switch, possible? I was told to tap into the headlight switch thing, what is this?
Thanks for your help.
Electronic Newb
Electronic Newb
