  • 1994 - 1995 Specific Tech
Tach square wave signal source
  • Thread starter Thread starter toyman
  • Start date Start date Apr 19, 2008
toyman
1,944
54
79
Vernon BC
Apr 19, 2008
  • Apr 19, 2008
I just installed a ZT-2 WB data logger. The rpm input was taken from the coil. The rpm display on the laptop shows large flucuations at idle. The install instructions indicate that the coil is an okay input source but also references a tach square wave connection as the preferred location. What are they talking about and where would I tap into this point?
HISSIN50
34
129
Apr 19, 2008
  • Apr 19, 2008
Seems to me that the PIP generates a square wave. The thing is that it's rough and gets cleaned up in the EEC, so I'm not sure how that would work.
I also don't know if an aftermarket ignition box has an output terminal with a square wave or if a little add-on module can be added. With your blower, I wasnt sure if you already had a box or not.......................
toyman
1,944
54
79
Vernon BC
Apr 19, 2008
  • Apr 19, 2008
Stock ignition. I'll check with a parts store to see if they have something like you suggested.
How to get a tach signal for N2O RPM window switch.
  • drofdeath
  • Oct 6, 2023
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2023
drofdeath
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Tach lead from coil
  • toyman
  • Apr 15, 2008
1994 - 1995 Specific Tech Apr 16, 2008
toyman
M90 root blower how to info
  • 1987LXragtop
  • Jan 7, 2011
  • SN95 V6 Mustang Tech
9K
SN95 V6 Mustang Tech Jan 7, 2011
1987LXragtop
