  • SN95 4.6L Mustang Tech
tail lights help asap
  • Thread starter Thread starter ascoldasice17
  • Start date Start date May 29, 2007
First Prev 2 of 2
89 White LX
15
Alabama
May 29, 2007
#21
  • May 29, 2007
  • #21
gimme the year and all that stuff , i will look it up
89 White LX
15
Alabama
May 29, 2007
#22
  • May 29, 2007
  • #22
LEFT Rear
Hotwire is LG/O
Ground is BK
RR
hot is - O/LB
Az Pete
711
18
49
Panama City, Fl.
May 30, 2007
#23
  • May 30, 2007
  • #23
New bulb cost a couple bucks. Buy one, replace the bulb, then if it still does not work, return for ideas. Don't make a bad bulb more work than it is. If the one bulb in the light assembly is flashing and one is not. It is 99% a bulb problem.
supastang03
214
Miami/Gainesville UF
May 30, 2007
#24
  • May 30, 2007
  • #24
Kilgore Trout said:
Have you checked your blinker fluid? It could be low? Are you running full synthetic?
either that or his turn signal belts may be sliding off a pulley..
gnat
144
#25
  • May 30, 2007
  • #25
way to fix a bulb that doesn't blink? Replace it. Doesn't matter if you've looked at it and it looks fine. It's evidently not.
ascoldasice17
92
Mays Landing, NJ
May 30, 2007
#26
  • May 30, 2007
  • #26
ive tried new bulbs and bulbs that do work and its the same things so now what boys?
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
May 30, 2007
#27
  • May 30, 2007
  • #27
Do you have a digital volt meter?? Time to start testing to see if you are getting power to the socket
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
May 30, 2007
#28
  • May 30, 2007
  • #28
Ditto
If it is the wiring at the socket, then your ground is good and the power lead to the low filiment is good (because you said the bulb lights up when the headlights are turned on). It is possible that the power lead to the high filiment is loose or not getting power (which is why the bulb does not light for turnsignals or hazards)
time to break out the volt meter
Az Pete
711
18
49
Panama City, Fl.
May 31, 2007
#29
  • May 31, 2007
  • #29
Could also be a problem with the actual contact in the bottom of the socket. Sometimes, the contact will wear to a hollow shape and even a new bulb will not make proper contact. As mentioned, get out the meter and check for voltage.
First Prev 2 of 2
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 5:36 PM
AeroCoupe
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
