Tail Pipes
Ok, now that I got my o/r H, I need some bigger tailpipes. I currently have 2.5" pipes and looking into getting 3.5" pipes. Can any1 provide a link?
I have MAC flowpaths, will any tail pipe fit that?
Also, my current tailpipes are welded in to the hooks, so I'm not sure if the people replacing it will have a hard time.
Thanks
Just my opinion but I would keep the ones you have. There are no performance gains here. My reasoning is if you spend money on an exhaust it should at least gain you something. If you feel the need to spend money on just the visual aspect then go for it.
Nik_95Cobra said:
I've seen em all, 3.5" looks way overkill on the car, and the 2.5's look like pea shooters. IMO 3" is the best, it's what I run, and lookswise it's not too big or too small.
Huh ... what you got looks just right. Surprising.
do you have mac tail pipes if so you can bolt on bigger mac tails to what you already have .i'm putting maganflow tips over my flowmaster ones to give it a better look than the small 2.5s i have now
ok, one warning. Watch the length of the new tips, or you'll end up sticking out too far. That's my problem. If i was in Canada I'd check the length of my tips and let you know. I think they're about a foot and half long, but you'll only be able to cut back so far into the stocker until it's bending up over the axle. Best bet is to find a shorter pipe, or you'll have to cut and grind your new ones down a bit. hope that helps
