take a look at this x-pipe, is it worth buying?
I was thinking about buying this x-pipe, but obviously from the looks of it it is used, and was cut then re-welded above the cats to gut them out. and take a look at the pipe in the foreground, where the weld is there almost appears to be a hole, am i mistaken in thinking this?? please give me your opinions, should i get it??
Looks like they cut it and then re-welded the pipes to make it fit "better". If you can get it for cheap I would say it is a good buy.
I don't think that is a hole in the pipe. Looks the same as the other black stuff in the photo.
I had to do the same with my bbk x pipe with high flow cats. It is still worth buying as long as the cats are good.
btw it will only cost like $20 to have it cut and rewelded if you need to.
