tell me about timing.
  • Thread starter Thread starter dastang2
  • Start date Start date Oct 1, 2006
dastang2
2,020
tx
Oct 1, 2006
  • Oct 1, 2006
can somebody tell me about ignition timing. what is initial and what it total timing. i need to understand this so i can time my car right. i marked the balancer at 12 and turned the dizzy until the mark lined up with the pointer.
JChalfan
551
Bellevue, WA
Oct 1, 2006
  • Oct 1, 2006
Initial timing is set with the spout removed. The spout is the little grey plug on the wiring harness right by the dizzy. Removing the spout makes it so the ECU can't change timing at all. The timing is locked in at its base setting. When you put the spout back in, the computer is able to adjust ignition timing based on engine load, rpm, etc.
Total timing is the most advanced the computer can make the timing. It is a function of whatever you set base timing at, plus whatever the computer can add to that. Setting total timing really isn't a concern with 5.0's.
To set your timing, first make sure you remove the spout! Then set the timing where you want it. 10* is stock, good for 87 octane. Most often you can go to 14* with no pinging, but you will have to run 92 or 93 octane gas. Once you set the timing where you want it, tighten down the dizzy, put the spout back in and go drive it! Listen to make sure it's not pinging. If it is, either bump the timing back 1 or 2*, or run higher octane gas.
Jeff
dastang2
2,020
tx
Oct 1, 2006
  • Oct 1, 2006
ok so i am doing it right, it has no efi. i forgot to mention thanks.
aleborjas
610
  • Oct 1, 2006
in a A9L and A9P if you set it at 12* where should be the total timing at? i whan to know how many degrees the computer advance at WOT
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
New to this
  • 5.ohCS
  • Nov 1, 2026
2005 - 2014 S-197 Mustang -General/Talk- Nov 1, 2026
5.ohCS
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
