  • SN95 4.6L Mustang Tech
Tell me about...
  • Thread starter Thread starter trinity_gt
  • Start date Start date Aug 7, 2004
trinity_gt
3,125
81
99
Canada
Aug 7, 2004
  • Aug 7, 2004
...the Diablo Predator. Specifically, 2V, mildly-modded, normally aspirated dyno results done under remotely controlled circumstances.
I'm at 255-ish rwHP right now with a few simple bolt-ons. I've heard good things about adding a few degrees of timing through a Steeda T/A but with piggyback March pulleys on my GT, the T/A isn't going to happen. The ability to tweak fuel a tad as well as correcting for gears (future mod) sounds very tempting. Having said this, rpmoutlet's copy sounds suspiciously like it was written by a marketing guy who doesn't actually know what a dyno is:
"Average power gains are in the 15-20 RWHP range. The DiabloSport Predator additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs."
15-20HP? I doubt it. "Frenzy"? I doubt this too. So what's realistic to expect? Any dynos to back up the numbers? Any other feedback?
01mgvert
302
  • Aug 7, 2004
I have the Diablo Predator and use it on my 2001 GT. It was great for re-calibrating the speedometer due to 4.10 gears. The performance tune, however, has much to be desired. If you buy a chip, Diablo tailors the chip for your specific mods. With the Predator, there is a single performance mod and it appears to be for a stock GT. With my mods, it really leaned out my car. Although you can adjust the a/f ratio, you are basically shooting blind unless you have an a/f monitor. I decided to have my car dyno tuned when I had LT headers installed. The mechanic used the Predator to make adjustments to the performance tune. I gained 23 rwhp with the LT headers and o/r x-pipe. I am not sure how much should be attributed to the Predator. I do know that the mechanic would have preferred to dial-in a chip than to make hit-and-miss adjustments with the Predator.
smokin 04
94
TWO HARBORS, MN
Aug 7, 2004
  • Aug 7, 2004
I installed my Predator tune about a week ago, I am very happy so far. I say to 15-20 HP claim though. I would guess 8 mabye 10 HP. I did seem to crispen up the throttle response and it seems to pull harder in 4th gear. Havent had the vehicle on a dyno yet but will soon. You add the modest HP increase with the ability to adjust the speedo and turn off the O2 sensors and I think it is a worthwhile purchase.
smokin 04
94
TWO HARBORS, MN
Aug 7, 2004
  • Aug 7, 2004
From what I have read Diablo can write a tune for your specific mods and you can download it into your Predator then install into your car
trinity_gt
3,125
81
99
Canada
Aug 8, 2004
  • Aug 8, 2004
I assume then that the Predator can also read and save the factory tune, right, and can program it back in? Can it store multiple flash reads? Say, the factory tune and one or two of my own?
J
Tune Causing Problems
  • Jarn
  • Jan 1, 2020
2K
1996 - 2004 SN95 Mustang -General/Talk- Jan 8, 2020
OneSick99GT
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
Tell Me All About E-85
  • sneaky98gt
  • Feb 25, 2010
1996 - 2004 SN95 Mustang -General/Talk- Feb 26, 2010
bhuff30
  • Locked
TURN-KEY TURBO BIG BORE 347 DSS AFR 614 RWHP/657 RWTQ
  • speedshifter
  • Feb 6, 2011
  • Engine and Power Adder Parts
8K
Engine and Power Adder Parts Feb 27, 2011
speedshifter
  • Locked
FS: HBH's 2003 Sonic Blue Cobra, 10K miles, 700+ HP, FULLY BUILT FRONT TO BACK!
  • sjstang
  • Dec 13, 2009
13K
SN95 Mustangs For Sale (1994-04) Dec 29, 2009
sjstang
