Test connector for codes
  • Thread starter Thread starter ARTTII
  • Start date Start date May 25, 2006
A
ARTTII
272
Detroit, MI
May 25, 2006
  • May 25, 2006
Anyone have a picture of one? I'm looking at my Ford Fuel Injection EFI conversion harness and cannot figure out just how to use it or if there is a cover over it... the part I think is a cover has the FORD oval script on it so I thought I'd ask you guys how you take it off or how to get at the actual connection points...
Thanks for any help! I'm lost on this one...
A
ARTTII
272
Detroit, MI
May 25, 2006
  • May 25, 2006
p.s. I'm assuming that it must be a cover over the connector - I'm sure I'm looking at the right connector, just can't get the cover lifted off...
The link always posted for a typical code scanner shows this:
http://www.actron.com/product_detail.php?pid=16153
So I'm assuming this will plug in underneath there (or I'm planning on using the "other" paper clip method). The plug I have is generally that size/shape but there is no holes... so is there usually a cover?
thanks
HISSIN50
34
129
May 25, 2006
  • May 25, 2006
My fox doesnt have the cover but my 94 does. The cover on the 94 just slides off. You have to wiggle it side to side (rock it) to get it to come off.
A
ARTTII
272
Detroit, MI
May 26, 2006
  • May 26, 2006
Ok thanks I'll try to force it somemore, just seems like anymore force I put on it then it will be ready to break... If that does not work I'll post a picture of it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 26, 2006
  • May 26, 2006
HISSIN50
34
129
May 26, 2006
  • May 26, 2006
All right, JRichker!
Just wiggle it back and forth - mine had dust and dirt stuck inside it. I actually had tried to use needlenose pliers to remove the cover (being very careful of where I put the jaws) but that wasnt going to fly. Simply holding the cover firmly while rocking the actual connector back and forth got it to come loose.
Good luck.
A
ARTTII
272
Detroit, MI
May 26, 2006
  • May 26, 2006
Thanks for the great pictures!
I got the cover off, man it was a fight for that little piece of plastic
Under the cover were the STI connector and the one shaped like the above picture. I was able to pull the codes with no problem. I just started a new thread on help with the codes (code 22).
:SNSign:
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
