TF Track Heat, 1.7RR & E303
  • Thread starter Thread starter Fri Guy
  • Start date Start date May 30, 2007
F
Fri Guy
435
259
83
May 30, 2007
  • May 30, 2007
Is anyone running some Track Heat heads with 1.7RR's & a E303 cam? If so, did you have any problems with P/V clearance???
GT_Rich
172
North Canton, OH
May 30, 2007
  • May 30, 2007
FWIW - I run almost that setup (B instead of E). I clayed mine during the install and had a 1/4 inch of clearance. I would expect you to be alright, but since it only takes another 20 minutes, clay to be sure
F
Fri Guy
435
259
83
May 30, 2007
  • May 30, 2007
The B cam has more lift than the E cam, right?
GT_Rich
172
North Canton, OH
May 31, 2007
  • May 31, 2007
No - the B has less lift, but more duration. Remember, max lift is not what affects P-V clearance the most, it's the total cam profile. Think about it as which cam is quicker to get out of the way.
F
Fri Guy
435
259
83
May 31, 2007
  • May 31, 2007
So then I should have more clearance than the B cam?
GT_Rich
172
North Canton, OH
May 31, 2007
  • May 31, 2007
E cam: More lift, less duration
B cam: Less lift, more duration
Without a software program to run through the kinematics of the system, you need to check it. Simple as that. Clay is two bucks and it will take you 20 minutes.
F
Fri Guy
435
259
83
May 31, 2007
  • May 31, 2007
I understand that clay is $2 & it will only take 20 min but I don't want to buy the heads & RR's & it not work. That is why I was asking if anyone has had any problems with this set-up.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Autolite 3925 discontinued?
  • 387lx
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2026
Mustang5L5
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
