TFI module removal?
  • Thread starter Thread starter Aliate X
  • Start date Start date May 26, 2005
Aliate X
602
Rockland NY
May 26, 2005
  • May 26, 2005
Whats the easiest way to change this thing? It looks to me like Im gonna have to remove the distributor....any tips? Different ways of going about this?
My car bogs when I shift quick like in a race, was hoping this would fix it.
J
jerryD
1,061
Gladstone, MO
May 26, 2005
  • May 26, 2005
don't have to pull the distibutor. just loosen it and rotate it. just mark where it was at before moving it.
Aliate X
602
Rockland NY
May 26, 2005
  • May 26, 2005
oh okay good stuff, thanks man.
pricha
466
St.Catharines,Ontario,Canada
May 26, 2005
  • May 26, 2005
In my experience either the TFI module works or it doesn't. A bad coil might act up like that when it gets hot but the TFI is more of an all or nothing thing. If the car runs it works!!!!!
Pat.
stang22
1,318
Washington, D.C.
May 26, 2005
  • May 26, 2005
Pat.
I would agree with you, but my symptoms were the opposite. I had a horrible miss at 3500rmp and I tried everything. I changed out the module and my miss went away.
Tim
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 26, 2005
  • May 26, 2005
You will have an easier time changing the module by getting the tool ahead of time. There is a specific tool that will allow you to easily get to the bolts on the module. You can get it at an AutoZone type place for about $7.
HISSIN50
34
129
May 26, 2005
  • May 26, 2005
Agreed with Adam - it is something like a thin walled 5.5MM socket.
mark and rotate the dizzy to acess the TFI. Service it (heat sink grease works well) and swivel the dizzy back to your marks. then set it exactly with a gun.
good luck.
J
jerryD
1,061
Gladstone, MO
May 26, 2005
  • May 26, 2005
it is a 7/32 deep wall thin well. but the special tool is alot better.
here is what my TFI tool looks like
Aliate X
602
Rockland NY
May 26, 2005
  • May 26, 2005
Im confused, if you still have to spin the dizzy to access the screws then why not use just a regular screw driver?
J
jerryD
1,061
Gladstone, MO
May 26, 2005
#10
  • May 26, 2005
  • #10
the factory bolts are not slotted for a screwdriver
Aliate X
602
Rockland NY
May 26, 2005
#11
  • May 26, 2005
  • #11
Oh okay, thanks a lot.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
