in the summit catalog there is a trick flow track heat kit that they say will bump u up to 360hp. what would the actual numbers be? and would it be worth it to upgrade the kit to the r-series manifold and the stage 2 cam?
I dont know if the Trick Flow kit comes with pistons, but if you decide to go with the stage two you will have to address piston to valve clearence issues.
