  • 1994 - 1995 Specific Tech
THE BEAST IS ALIVE!!!!!
  • Thread starter Thread starter StinkinLincoln
  • Start date Start date Jun 16, 2007
StinkinLincoln
240
Louisiana
Jun 16, 2007
  • Jun 16, 2007
im so freakin happy!!!!!!!! i got a small oil drip from like the rear main seal, its drippin into the end of the bellhousing, were not sure what it is yet but were trying to figure it out! i got a couple idol and mid rev videos on photobucket! check them out!
it was idling about 1 grand so its no too lopy, when we were setting the timing and it was about 800rpms it sounded freakin sick!
http://smg.photobucket.com/albums/v97/DEER_HUNTER132/?action=view&current=rev1.flv
http://smg.photobucket.com/albums/v97/DEER_HUNTER132/?action=view&current=rev2.flv
Stanger007
2,015
Baton Rouge, LA
Jun 17, 2007
  • Jun 17, 2007
Congrats man!
Can't wait to see it!
Wes
juiced_94gt
1,143
Southern California
Jun 17, 2007
  • Jun 17, 2007
whats your 331 combo consist of?
BlackVert
5,589
9
98
Bethesda, MD
Jun 17, 2007
  • Jun 17, 2007
StinkinLincoln
240
Louisiana
Jun 17, 2007
  • Jun 17, 2007
all that stuff in my sig LOL
but some of that i need to get and is on my list once i get the funds...
if you guys could help me out...i got a pretty bad oil leak and its dripping through the end of the bellhousing, so were not sure where its coming from...if i had a diagram of the rear of the engine with a auto tranny next to it...then maby we could figure out where its coming from. i might have to crawl around under there and see whats going on...i dont want to have to pull the engine just to fix a freakin gasket...maby; depends on where it coming from, the engine wont have to be pulled and it can be fixed with the tranny out since im going to get it rebuilt anyways.
1995 Mustang GT
331 Stroker
Fender CAI
70mm TB
75mm Pro-M
30lb'ers
255lph
Edelbrock RPM 2 upper/lower
Manifolds Edelbrock RPM heads 60cc 2.02 intake valves
XE270HR comp cam (1800-5800rpm)
shorty equal lengths
gutted stock exhaust
10.0:1 to 10.5:1 CR
Things for the "to get/install list" Rebuild AODE tranny with new clutches, 26 spline input shaft,and the whole nine yards.
3000 Stall from Edge Racing
deep alum. pan with tranny cooler
remote tranny filter
MT ET Street 255/50R16 on stock rims
adjustable upper and lower Control Arms
Strange 10 way Adjustable Shocks
Subframe Connectors
Alum. Driveshaft
3.73's
31 Splines
Differential Rebuild
Tweecer R/T with Wideband Sensor
50-100 shot
post guesstimate 1/4 times. hoping to see 400rwhp N/A (prob closer to 350-375) and 11's...and if not im spraying!
the bold stuff i have already. the tweecer is on it way though.
Stanger007
2,015
Baton Rouge, LA
Jun 17, 2007
  • Jun 17, 2007
It's either the rear main, back of intake, valve covers or oil pan - probably in that order.
A trick I've used before is to clean everything up real well, run it a bit then puff some baby powder and it will stick to the fresh oil leak.
Wes
StinkinLincoln
240
Louisiana
Jun 17, 2007
  • Jun 17, 2007
thanks im going to try that!
im going to jack it up tomorrow and get her a look see.
C
New Guy Needs Help
  • CFerreirax24
  • Jul 28, 2012
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 29, 2012
slayerripkdc
Iron Oxide, AKA RUST!!!
  • firemansam
  • Aug 10, 2011
2K
Classic Mustang Specific Tech Sep 24, 2011
firemansam
Had a Lil Fun
  • 4Jenna
  • Apr 8, 2012
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 16, 2012
4Jenna
Nuts
  • mustangmutt
  • Jun 13, 2011
Classic Mustang Specific Tech Jun 14, 2011
robbz28
New Video :D
  • StinkinLincoln
  • May 30, 2009
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2009
SeventyMach1
