the best is not working
  • Thread starter Thread starter canesstangnitro
  • Start date Start date Sep 4, 2006
C
canesstangnitro
109
Metairie, LA
Sep 4, 2006
  • Sep 4, 2006
my car has not been working the last 2 days. I have a '87 lx 5.0. my car has been not wanting to go when I drive. It feels like if you were riding with your emergency brake on or if there was a chain and a truck pulling it the other way. I hope someone has had this problem before because this is my daily driver and I need to get it fixed. it is a manual transmission and when I start driving it just feels like I cant go. the car will drive but I cant go fast, like if you were driving with your emergency brake on but my brakes dont smoke when I am done driving. I jacked up the back part of the car today and started the car. I had it in first gear got out and the tires were spinning but when I had it in neutral the tires were harder to turn. I dont know if my emergency brake on my wheel is stuck or if the brake cylinder is old and needs to be changed. please help this is my daily driver
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2006
  • Sep 4, 2006
Get the car up to 30 MPH & take the car out of gear and see how far it rolls. It if doesn't roll very far you may have brake problems.
C
canesstangnitro
109
Metairie, LA
Sep 5, 2006
  • Sep 5, 2006
it was a blown clutch
TomCat
412
Utah
Sep 5, 2006
  • Sep 5, 2006
While your dealing with the clutch system, get rid of that stock quadrant!
HISSIN50
34
129
Sep 6, 2006
  • Sep 6, 2006
A clutch would not have been my first guess. That doesnt quite match some of the symptoms pointed out in the opening post.
Anyhow, good luck and let's hope it's all fixed.
TomCat
412
Utah
Sep 6, 2006
  • Sep 6, 2006
You're right... that doesn't match at all
C
canesstangnitro
109
Metairie, LA
Oct 18, 2006
  • Oct 18, 2006
it was not grabbing
the car felt like I was driving with my emergency brake up because the clutch was not grabbing when I was driving. the clutch should bite when you let go of the clutch and it was not grabbing. I put a centerforce dual friction clutch in it last week and now it grabs
R
Ryano
12
  • Oct 22, 2006
It is possable that your brakes are draging an it caused it to burn the clutch up! If someone reads this and has a question as to weather there brake are draging take your hand and place it close to the rotor, feel for heat, then feel the other side and compare. To release the drag (quick fix)take a screw driver and get under the rear and pry the cable back, then you of corse fix the problem.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Nov 12, 2026
ctandc
C
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
  • brandyn200
  • Jun 20, 2026
AeroCoupe
