The dreaded tick
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Oct 28, 2005
1 of 2 Next Last
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Oct 28, 2005
  • Oct 28, 2005
So i was tightening my headers today. I started the car back up and noticed there was a tick coming from the passenger side valve cover. Im thinking its a lifter or something.. Any Ideas on how to fix this?
legalize420
1,541
South Florida
Oct 28, 2005
  • Oct 28, 2005
i would think that if anything in the valvetrain is making the noise, it would be the rockers. what have you done to the car lately? did this just start happening?
89/GT/Vert
Spring, TX
Oct 28, 2005
  • Oct 28, 2005
Maybe an exhaust leak, somehow happened when you were tightening your headers?
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Oct 28, 2005
  • Oct 28, 2005
Im thinking exhaust leak since you were messing with your headers
89white50
440
central MA
Oct 28, 2005
  • Oct 28, 2005
yea i had the same problem after i put my new headers on, then retightened my headers and it noticeably went away. Exhaust leaks really can sound like ticking rockers or lifters.
RsStanG1987
569
9
79
Dupont PA
Oct 28, 2005
  • Oct 28, 2005
Nope not headers. They are all tight. The leak was on the drivers side not the passenger. It just started redently.
legalize420
1,541
South Florida
Oct 28, 2005
  • Oct 28, 2005
you have stock heads and rockers right? have you messed with the valvtrain at all? if not, i doubt anything came loose. is this the same tick you heard when you had a leak? i had a loose rocker and leaking header gasket in the past and they sound nothing alike. the header leak was a tick, the loose rocker was a more noticable banging noise.
RsStanG1987
569
9
79
Dupont PA
Oct 28, 2005
  • Oct 28, 2005
Its hard to explain but its not the same as the leak..
Mavrick
2,264
Collingwood, ON
Oct 28, 2005
  • Oct 28, 2005
Exhaust leak sounds like a tick whereas valvetrain rattle sounds more like a clack. A bad lifter would also be a kind of ticking..
RsStanG1987
569
9
79
Dupont PA
Oct 28, 2005
#10
  • Oct 28, 2005
  • #10
Like i said the exausht is thight i think its a lifter.
ej95cobra
82
Southeastern PA
Oct 28, 2005
#11
  • Oct 28, 2005
  • #11
check to make sure all your plug wires are on firmly. They'll make a similar noise if not properly seated.
dkins419
187
Michigan
Oct 28, 2005
#12
  • Oct 28, 2005
  • #12
Not to steal this thread or anything, but i think my rockers are ticking. Anything wrong with the rockers ticking? It just all of a sudden starting happening about a month ago. This was one day when i started it up after normal driving.
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Oct 28, 2005
#13
  • Oct 28, 2005
  • #13
It's that f'in time bomb you have for an engine
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 29, 2005
#14
  • Oct 29, 2005
  • #14
Mine ticks a little with 5W-30 in it, but sounds fine with 10W-30. Not sure what oil you are running.
W
WhiteHeat306
283
Philadelphia Suburbs
Oct 29, 2005
#15
  • Oct 29, 2005
  • #15
Maybe you busted a valve spring?
pb_paulie_b
894
Chaptico, Maryland
Oct 29, 2005
#16
  • Oct 29, 2005
  • #16
i developed a 'tick' in my 90' gt. it turned out that i stretched a rod. i didn't find out till the valve got stuck through the piston when it let go. i'm not sayin you have the same problem jes that it's worth lookin into...PB
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 29, 2005
#17
  • Oct 29, 2005
  • #17
Pull the valve cover and check it out. Fact is higher milage vehicles can make some annoying sounds, find out if its a rocker/lifer, and if you need to worry about it by taking a look.
ninety15.0
1,336
#18
  • Oct 29, 2005
  • #18
if you pull the valve cover off are you going to need to replace the gasket and $hit?
pb_paulie_b
894
Chaptico, Maryland
Oct 29, 2005
#19
  • Oct 29, 2005
  • #19
naw. it would be a good idea if it's leaking. i've reused them lots of times. some time ago i invested in steel reinforced ones. they are money!...PB
ninety15.0
1,336
#20
  • Oct 29, 2005
  • #20
yea the reason i asked...i just got back inside from ripping the pass side VC off my car to check the rockers b/c of a ticking issue. I also have the reinforced gaskets...they went back on fine...thnx
1 of 2 Next Last
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
9
Unknown engine tick
  • 94 Daily
  • Oct 31, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
91AOD5.0LX
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
