  • SN95 4.6L Mustang Tech
the edometer light, dome a little when ever I push the window up or down ?
  • Thread starter Thread starter Killa
  • Start date Start date Aug 17, 2008
Killa
1,006
56
49
Aug 17, 2008
  • Aug 17, 2008
When I ever I push the window up or down, it edometer or inside light is dim a second, and my engine is bog down for just same second. is this normal ?
D
darkside03gt
851
Sacramento CA
Aug 17, 2008
  • Aug 17, 2008
not really. you might have a bad ground or two.
my lights only dim when i try to roll my windows up when they are already full up. but that is because of the load on the motors.
Killa
1,006
56
49
Aug 18, 2008
  • Aug 18, 2008
yea my bad, my car does the same as your, is that normal ?
D
darkside03gt
851
Sacramento CA
Aug 18, 2008
  • Aug 18, 2008
iam guessing it is.
blckstng96
208
  • Aug 18, 2008
mine does,i can see that as being normal,your putting strain on the motors in turn extra draw on the electrical system.i wouldnt be worried.just don't do that anymore,you'll burn out your window motors haha and they are a bitch to change.
RedDaemon
3,470
9
108
Atlanta, GA
Aug 18, 2008
  • Aug 18, 2008
'03GTinFLA said:
Mine doesn't do that because I have UDP's on my window motors. Some people say it's a bad idea because it's harder on your window motors, but I feel it's all in the installation. As soon as I get some more mods on my window motors I'll get them dyno tuned but it's not worth if with just UDP's.
for a second i thought you were actually trying to help him.
my 99 GT does the same thing Killa im not worried about it
D
Drew0318
115
Chicago, IL
Aug 18, 2008
  • Aug 18, 2008
I think it's fairly normal. I've got a '99 and it does the same thing. I don't think Ford put particularly strong alternators on them.
One way to remedy it is to get a bigger one. I think the factory Ford alt is 130A, at least that's what I've seen as a "replacement".
Personally, I'm not worried about it too much.
The same thing can (and does) happen with big sound systems and under-rated alternators. When the booms hit, the lights brown out (speaking from experience from my youth).
So, if it really bothers you, you can probably upgrade your alternator, but they're rather salty.
joshjwc9
1,095
17
39
Palm Harbor, FL
Aug 18, 2008
  • Aug 18, 2008
Try grinding the paint off of the grounds on the core support, they are painted which equals a poor grounding surface....it helped mine some, but my driver tweeter is still having a light whistle because it is grounded poorly.
Mustang5L5
Mod Dude
Feb 18, 2001
43,298
18,003
224
Massachusetts
Aug 18, 2008
  • Aug 18, 2008
WTF??
To the OP. Electric motors can draw a lot of power when "jammed". So yeah it's normal...but try not to do it
rabidscoobie
616
12
48
College Station,TX
Aug 19, 2008
#10
  • Aug 19, 2008
  • #10
Its normal,my 01 gt did it and so does the Mach.So did every camaro and TA I owned and I have had a few of those.
Killa
1,006
56
49
Aug 19, 2008
#11
  • Aug 19, 2008
  • #11
my passenger side, I can roll my window up but I cant roll it down ? new motor time ?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 19, 2008
#12
  • Aug 19, 2008
  • #12
Will it roll down with the passenger side control?
Killa
1,006
56
49
Aug 19, 2008
#13
  • Aug 19, 2008
  • #13
Im feel like a retard, for not to give full details .
I can control passenger side to roll up and down , using driver side control, but on passenger control , It can only roll up, but cant roll down.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 19, 2008
#14
  • Aug 19, 2008
  • #14
It's the switch on the drivers side control. You may find one cheap in a junkyard but new they are a bit expensive.
'03GTinFLA
486
St. Petersburg, FL
Aug 19, 2008
#15
  • Aug 19, 2008
  • #15
Mustang5L5 said:
WTF??
It was a joke. I felt it was pretty obvious that his question was answered and mine was meant to be funny. I've seen downright offensive, and also funny, responses on here that weren't deleted. WTF??
Killa
1,006
56
49
Aug 19, 2008
#16
  • Aug 19, 2008
  • #16
wat year of mustang do i looking for ? when im going to the junkyard.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 19, 2008
#17
  • Aug 19, 2008
  • #17
Anywhere from 96-04 should fit. Check one of the parts sites to be sure. PM Randy Stinchcomb for the part number. He could tell you what will fit for sure.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 19, 2008
#18
  • Aug 19, 2008
  • #18
If you see something offensive then report the post. Otherwise we try to keep tech as on topic and helpful as possible. Feel free to PM me if you feel slighted.
F
faststang_728
558
Greenbrier, WV
Aug 21, 2008
#19
  • Aug 21, 2008
  • #19
I wouldn't be so quick to condemn the switch. I could just as easily be a wire. No need to replace a good switch.
BTW what the hell is the edometer?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 22, 2008
#20
  • Aug 22, 2008
  • #20
True...but the harness would be easy to inspect.
I think he meant odometer. No biggie
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
J
Windows won’t go up when car is running
  • Jraesims
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
