The SN65 project car
  • Thread starter Thread starter SN65
  • Start date Start date Oct 27, 2004
  • 14
  • 15
  • 16
  • 17
  • 18
  • 67
First Prev 16 of 67 Next Last
Edbert
3,548
32
109
Austin TX
Apr 25, 2005
#301
  • Apr 25, 2005
  • #301
c3dlc said:
http://www.idpz.net/c3dlc2/jamais-surpris.com/.dtc
I'm not suprised you speak French either.
Sicarius428
2,085
Apr 25, 2005
#302
  • Apr 25, 2005
  • #302
This is so exciting... and the damn thing isn't even mine! How unfair.
Kevin
L
limey66
408
Northampton, England
Apr 25, 2005
#303
  • Apr 25, 2005
  • #303
This is great!! Been following the thread for months, and now it's all coming together.
Keep it up, turning that key can only be a couple of weeks away...
Platonic Solid
1,960
CT-USA
Apr 25, 2005
#304
  • Apr 25, 2005
  • #304
SN65 said:
For those who wish to know, we used "Duramix 4040" to bond the FRP fender flare to the steel quarter panel. 4040 is a specialty adhesive used for both structural and cosmetic repairs.
Cool stuff!! More toxic toys to add to my garage. Here's a link I found that gives more info.: Duramix
SN65
540
Chicago, IL
Apr 26, 2005
#305
  • Apr 26, 2005
  • #305
Hi All,
Yesterday was a tough day.
After much debate, we decided to powder coat the front spindles and the rear lower control arms. I was wishing to keep them natural, but I was beaten into submission by the rest of the guys in the shop. Both items had a few cosmetic issues (stains in the castings and inconsistent surface texture) that just did not look right. I dropped these items off at the powder coater, but they will not be ready until Thursday, which is going to slow us down a bit on the assembly.
Also, I found out that it will be a week or two before we can receive a cooling mod kit from LDC Chicago. This means that we are going to have to continue with the Apten kit and make it work as best we can. I am sure we can get it to fit up right, but it would be a lot easier with the LDC Chicago kit. This is also going to slow us down a bit.
Wayne finished off the interior of the flares by grinding all the surfaces smooth and "filling / skim coating" the inner gaps and contours with the same 4040 material used to bond the flare to the quarter panel. Once we apply the undercoating to the inside of the wheel housing, it will look perfect. When he was done with the flares, he started skim coating the roof and the top of the cowl area.
Just for grins I posted a close up of the chassis (of the fuel and brake lines between the rear frame rails). If you look close you will note that we are using 3m strip caulk at all the pop riveted and screwed components (you can see it ooze from behind some of the mounted items). This may be a little excessive, but we feel it is good insurance against any rust weeping from where the fastener scratches the coating during installation.
Today we continue to detail and assemble as many parts as we can. We will concentrate on the suspension and chassis as well as finishing off the engine cooling modification.
Wish us luck today, we are going to need it.
SN65
Come see this WIP at
Julian's Collision Center
http://www.julianscollisioncenter.com/
StaffAmerica74
120
Easton, Pa
Apr 26, 2005
#306
  • Apr 26, 2005
  • #306
Excellent work there.... cant wait to see it complete, that thing looked mean when it was on the ground before you had it media blasted. GOOD LUCK with it.
shelbe67
309
Apr 26, 2005
#307
  • Apr 26, 2005
  • #307
what kind of paint are you using? is it a single stage paint? I was just wondering this thing looks awesome you really give me a reason to go and work on mine!
J
Jc69Stang
95
#308
  • Apr 26, 2005
  • #308
Great Work. Keep it comming!
SN65
540
Chicago, IL
Apr 27, 2005
#309
  • Apr 27, 2005
  • #309
Hi S,
We are using a PPG basecoat clearcoat system. It is interesting to note that the PPG number for the 05 Screaming Yellow base is 666.
Good luck on your project.
Catch you l8r
SN65
MrBobMarley
460
Ft Myers, FL
Apr 27, 2005
#310
  • Apr 27, 2005
  • #310
Wow, been awhile since I've been on here. Looks awesome man. I can't wait to see a fender shot with ther flares next to the photoshop. Are you still set on the 2003 wheels or is there a surprise in the works?
Best regards. Keep on banging that thing out man, I can't wait to see/hear it.
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 27, 2005
#311
  • Apr 27, 2005
  • #311
Although pricy, some custom billet 17" or 18" styled steel lookalikes would be bomb-diggity
xj220
696
Apr 27, 2005
#312
  • Apr 27, 2005
  • #312
Keep the original 2003s, they'll look great.
Stang2Man
363
In the Hood of Newbern Beyotch
Apr 27, 2005
#313
  • Apr 27, 2005
  • #313
No way some 20" burick (buick to most of us) rims would be sweet on there, hehe
shelbe67
309
Apr 27, 2005
#314
  • Apr 27, 2005
  • #314
I know that you probably dont need them but are you gonna use some subframe connectors?
Route666
1,652
Brisbane, Australia
Apr 28, 2005
#315
  • Apr 28, 2005
  • #315
Well the devil is in the details.
SN65
540
Chicago, IL
Apr 28, 2005
#316
  • Apr 28, 2005
  • #316
Hi BM,
Glad to see you back.
I am still planning on using the 03 Cobra wheels. I may trade up to Cobra "R" wheels (or some other custom wheel), but I will make that determination after I get the car on its wheels.
Catch you l8r
SN65
SN65
540
Chicago, IL
Apr 28, 2005
#317
  • Apr 28, 2005
  • #317
Hi S,
No, we are not going to use subframe connectors. I believe the chassis is as stiff enough as is. Once we have the car on the frame rack again, we will perform some torsional tests on the chassis just to see how stiff it really is.
Catch you l8r
SN65
SN65
540
Chicago, IL
Apr 28, 2005
#318
  • Apr 28, 2005
  • #318
Hi All,
We did not get as far as we had hoped yesterday. Work raised it's ugly head and I had some issues that needed my personal attention. Also, I will have to go out of town next week so the schedule will slip a bit more. I guess that ain't too bad in that we will not have some of the parts needed to install the drivetrain. We really need a new clutch pressure plate, etc... and Centerforce says that they currently have 300 03 Cobra clutch setups on backorder.
Anyway, we have been plugging away on the IRS. The re-assembly and the installation of the Maximum Motorsports bushing kit is a bit more complex than we thought it was going to be. We thought "just insert the bushings and bolt it up, but no such luck. Lots of shimming and alignment issues. And you know us, we are not happy unless this thing lines up right on the button.
Anyway... Here is a shot of the IRS as it sits this morning.
While I am working on this, Wayne will be finishing the FRP work on the rear fender flares.
Well it is time to get back to work. Wish us luck.
SN65
monk302
742
New Jersey
Apr 28, 2005
#319
  • Apr 28, 2005
  • #319
SN65 said:
Hi All,
SN65
You should call them up and explain to them the creation you have put together. In addition send them a few pics and I would be very surprised if you weren't bumped up to the top of the list. Who knows, you might even get it discounted. This car is definitely going to get some publicity and I am sure Centerforce would be happy for a mention of one of their components in the car.
BullittFB
89
#320
  • Apr 28, 2005
  • #320
Whaddaya say you post centerforce´s mail address, and we all flood them with mail demanding your clutch???
  • 14
  • 15
  • 16
  • 17
  • 18
  • 67
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
WTB 89 Hatchback interior trim - any color
  • Zero_chance
  • Jun 14, 2026
  • Want to Buy
Want to Buy Jun 14, 2026
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
D
Hey Ya'll from the North Georgia mountains
  • dulcimerbob
  • Sep 11, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 18, 2026
John redcorn
J
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
