Hi All,
Yesterday was a tough day.
After much debate, we decided to powder coat the front spindles and the rear lower control arms. I was wishing to keep them natural, but I was beaten into submission by the rest of the guys in the shop. Both items had a few cosmetic issues (stains in the castings and inconsistent surface texture) that just did not look right. I dropped these items off at the powder coater, but they will not be ready until Thursday, which is going to slow us down a bit on the assembly.
Also, I found out that it will be a week or two before we can receive a cooling mod kit from LDC Chicago. This means that we are going to have to continue with the Apten kit and make it work as best we can. I am sure we can get it to fit up right, but it would be a lot easier with the LDC Chicago kit. This is also going to slow us down a bit.
Wayne finished off the interior of the flares by grinding all the surfaces smooth and "filling / skim coating" the inner gaps and contours with the same 4040 material used to bond the flare to the quarter panel. Once we apply the undercoating to the inside of the wheel housing, it will look perfect. When he was done with the flares, he started skim coating the roof and the top of the cowl area.
Just for grins I posted a close up of the chassis (of the fuel and brake lines between the rear frame rails). If you look close you will note that we are using 3m strip caulk at all the pop riveted and screwed components (you can see it ooze from behind some of the mounted items). This may be a little excessive, but we feel it is good insurance against any rust weeping from where the fastener scratches the coating during installation.
Today we continue to detail and assemble as many parts as we can. We will concentrate on the suspension and chassis as well as finishing off the engine cooling modification.
Wish us luck today, we are going to need it.
SN65
Come see this WIP at
Julian's Collision Center
http://www.julianscollisioncenter.com/
