those that relocated battery..
oosmytoo
530
Portland - Oregon
Since I already have two 4 gauge and a 1-0 wire connected to my fuse block under the hood. There really isnt much room for any other accessories to connect there. So I was wondering how to wire my tranny cooler fan, HID's, and MSD box, without having to run several wires to the trunk?
I have thought about running a 4 gauge wire from the battery, to a fused power distribution block. That would be hidden under the dash somewhere. Then make all my connections there?
what do you guys think?
You could probably pick up a distribution block to run the 1/0 wire to, and run the 4 gauge from there to the factory point. That would at least save you from running an additional wire from the battery. I'm not sure if you can put a longer bolt in the fuse box to compensate for the added thickness of the wire otherwise, but either way should work.
