Those who are using Trick Flow Tall Valve Covers
I run the TFS street heat and TFS tall valve covers. I had to run a one inch spacer. I am also runnning a 75mm throttle body and had to do some trimming on the throttle cable bracket.
TFS street heat with a 1 inch spacer. For the stock hood i had to cut one of the supports out on the driver side because it rubbed the intake and mad a wear mark on my black intake. grrr
Kevin
Same here. I also has a 2" cowl hood on it as well. When I trimmed my bracket I just elongated the mounting holes a little. It wasn't touching by much.
