  • 1994 - 1995 Specific Tech
Throttle body/ Idle
  • Thread starter Thread starter Danman765432
  • Start date Start date May 30, 2006
D
Danman765432
471
Nutley, NJ
May 30, 2006
  • May 30, 2006
i was just wondering if someone could just give me a picture of which screw to turn to change the idle since mine is way to low and is sitting now at 550 when in drive and it is making my car stall. Thanks
-Dan
HISSIN50
34
129
May 30, 2006
  • May 30, 2006
Dan, no pic here.
You have two options - turn the idle stop shank (it's like a screw with no head. You use needlenose pliers to adjust it since it's hard to access - it's under the STB).
Or you can adjust the IAC bleed screw. It's on the front of the IAC under a rubber plug. If you run it out too far, the idle will hang. I ran mine out as far as I could without the hanging idle (1.75 turns from being all the way in, IIRC) and then had to adjust the throttle stop shank.
I recommend putting a mark on each adjuster and recording all adjustments so you dont forget what you've done (I forget easy, esp when running things up and down).
Good luck.
D
Danman765432
471
Nutley, NJ
May 30, 2006
  • May 30, 2006
I think i need a new IAC. I changed the idle with the idle screw and actually set it pretty high. After driving around it dropped back down to 550. So do you guys think it is the IAC?
Therian
The Highlander
Waterloo, Ontario
May 30, 2006
  • May 30, 2006
Did you reset the computer after adjusting the screw?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
