Throttle Body Size
  • Thread starter Thread starter Sean B
  • Start date Start date Jan 7, 2018
Sean B
  • Jan 7, 2018
Hello everyone , looking for advice. I have a 1992 5.0 gt. I had a comp cam with .512 lift put in,flo-tek aluminum head 180cc/58cc and a gt-40 intake. My question is, what size throttlebody, MAF,and injectors should I use? Thanks.
Steel1
Mustang Master
Aug 18, 2017
1,419
639
143
Connecticut
Jan 7, 2018
  • Jan 7, 2018
I'm not sure what size the TB opening is on the GT40 intake but I would say for an n/a street car.
70MM Maf
65MM TB
24lb. injectors
Obviously if your planning on boosting it injectors etc. would change.
Also upgrade fuel pump if you haven't already.
Reactions: General karthief
cleanLX
976
537
144
Jan 8, 2018
  • Jan 8, 2018
GT40 "series" of intakes have 69mm-70mm TB throat.
So, TB 65mm or 70mm , MAM 70mm to 76mm... I doubt larger would hurt but the 70/76 will fit the stock air box.
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Jan 8, 2018
  • Jan 8, 2018
I agree with 65 MM throttle body, 24 lb injectors, and I recommend a 75mm Pro M MAF. A 70 MM TB would work, but the bigger you go the more your throttle responds tends to suffer slightly.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jan 8, 2018
  • Jan 8, 2018
if it were my car I'd find a 70MM MAF from a 94-95 GT and a 65MM TB from an Explorer and call it a day. You will need to do a little fab work to get them to work on the fox body but for under $100 you are set, I would leave the 19# injectos as you are not setting the world on fire with that combo
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
