I was looking under a guys hood last night that has a gt and he had something inbetween the throttle body and the plenum that was called a t/b spacer. Do those give much or any hp?
svttech76 said:do not buy a a plenum spacer. that will produce the same amount of hp as taking the money and burning it.
crapola
propellerhead said:Wow! Lots of slams towards the throttle body spacer.
A friend sold me his spacer for $20 so I put it on just for fun. I can't say I can feel a difference but that can be said for many many mods we spend our money on. Another friend of mine dyno'ed 3 rwhp more with just a throttle body spacer, but that's within the noise level of most dynos. The dyno sheet he has before the throttle body spacer and after were like a month apart. So there's nothing really conclusive there.
If you read the description of the Trick Flow plenum it says it is raised. I believe the idea here is to lengthen the travel between the bend of the plenum and the lower intake. This is intended to smooth out the airflow and have less turbulence. Does it add velocity to the air? I don't know. Either way, there has to be some gain there, even though it may be too small for our calibrated butts to feel. I wouldn't say it is a waste of money. I just classify it like the rear seat delete. It helps a little but not enough to really feel a difference.
McTeague said:I thought carb spacers were all about keeping the carb insulated from the heat of the intake![]()
