Throttle Kicker Solenoid
  • Thread starter Thread starter asecretfile
  • Start date Start date Apr 2, 2008
asecretfile
228
  • Apr 2, 2008
Where is this on an 87 GT?
thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 2, 2008
  • Apr 2, 2008
It is the IAC or IAB, same part, different name.
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes] for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
N
n2o-89fox
116
ca
Apr 2, 2008
  • Apr 2, 2008
LoL, never heard it called that before.
asecretfile
228
  • Apr 3, 2008
yea dumped the codes and the error code said that lol
88 Throttle Kicker Solenoid
Variable Voltage Choke relay circuit fault
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Apr 3, 2008
  • Apr 3, 2008
Codes 88 actually means a few things
88
Fan Control circuit fault
A4LD - Converter Clutch Override solenoid
Electronic Ignition - IDM, DPI or spout circuit fault
That's 5 things for one code. And which ones depends on what car. Mustangs don't have throttle kicker solenoids. At least I wouldn't consider the IAC one.
It's definitely not the middle 3 as you don't have a choke. You dont have an electric fan and your car doesnt have an A4LD.
I think yours is the last one.
With that said...is your SPOUT unplugged??
asecretfile
228
  • Apr 4, 2008
checked the spout connector and its in place
I did the FMS AC delete and repaired an old cracked vacuum line that I broke when I dropped a wrench and soon as I cranked it afterwards, car sounds cammed and its not..shakes the whole car at idle but oddly enough it doesnt stall. Engine hunts idle when slowing the car down and goes back to choppy idle...jumpy acceleration at low rpms but fine at higher
Did the carb cleaner vacuum check at all areas and no jump in idle
Maybe bad IAC or TPS?
thanks for responding
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Apr 4, 2008
  • Apr 4, 2008
Reset the computer, then drive the car around and dump the codes again and see if they repeat.
Black1987Stang
1,422
Jersey Shore
Apr 5, 2008
  • Apr 5, 2008
did you knock the vacuum line off the map sensor? if it still is Speed Density...
asecretfile
228
  • Apr 5, 2008
checked and its still on...when I was working on the vacuum lines I have like 3 vacuum T's on there and one vacuum coupling lol....could it be all the T's restricting the vacuum maybe? Its those T's that will fit different hose sizes and you just cut off the tips to the size you need
thanks
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
