What I "conveneintly" forgot to mention is the trouble shooting that led up to my little fix. I first thought the factory return spring on the throttle cable was weak. So, i took about 1" of 3\8" fuel line, split it, pulled the spring back off the plate or "stop" it rests against, & zip tied the hose on to increase the throttle return spring pressure. I still had a sticking throttle & it was even more difficult to modulate the gas pedal than before.
I then decided the throttle cable must have been kinked in the engine swap(former 4cyl car) & I bought a brand new throttle cable assembly from Ford. Wrong again!
I then sprayed WD40 around & under the throttle body; including under the TPS. It would "free up" for a day or two then return to it's sticking bastard self. Finally, a friend mentioned trying graphite. I couldn't find regular powdered graphite at the local store; but they had the spray graphite....
