  • 1994 - 1995 Specific Tech
Throw Out Bearing
  • Thread starter Thread starter FlyBy763
  • Start date Start date Oct 10, 2004
FlyBy763
439
Palm Bay, FL
Oct 10, 2004
  • Oct 10, 2004
So my TOB started making noise recently...I did a search on it and it seems its a pain to fix and some say it can cause damage eventually, and some say its no big deal...anybody want to chime in?
TrueBlue95GT
966
Connecticut
Oct 10, 2004
  • Oct 10, 2004
It's not a PAIN to replace, but it's more involved than changing an air filter. You're going to need two people for this job also. If you're doing the TOB, you might as well change the clutch also. Basically what you do is take off the h-pipe, take down the driveshaft, unbolt the tranny and take that down (shifter needs to come off), replace the TOB and installation is the reverse of removal.
RIO5.0
6,892
N.H.
Oct 10, 2004
  • Oct 10, 2004
I got both TO and pilot bearing at Napa....The TO was a plastic one??? never seen one before....have not had a lick of trouble and its quiet...I was kinda leary on the plastic, as i had never seen one before..
some cars eat TO bearings, my old TA use to need one a Summer it seemed...
Anyway...if your in there and you think its needed...do the clutch, pilot bearing and this is a good time to check out the rear main and replace it if needed...
Heres the Napa numbers on the TO/Pilot shaft bearing if interested..
FlyBy763
439
Palm Bay, FL
Oct 10, 2004
  • Oct 10, 2004
So I take it I should probably get it replaced or Ill be replacing a lot more if I dont?
RIO5.0
6,892
N.H.
Oct 10, 2004
  • Oct 10, 2004
You can get by for awhile with a light squeeling...its gonna get worse though..It'll tell you when its spent...I wouldn't let it get that far...Sometimes you can have a light squeel and it'll be more annoyance than anything....if you lightly touch the clutch and it goes away...thats not much...when she squeels all the way down and up...thats spent...
Ive taken them out and they been Black/Blue from the heat tint...once the grease is gone in the bearing...she starts squeeling/screaming bigtime... If let go to long, you can risk wrecking the pressure plate to...that bearings rubbing against it, and the bearings seized...NOT GOOD...
94GTStang
1,631
Oklahoma City
Oct 10, 2004
  • Oct 10, 2004
I kept having my t/o bearing whine on me. So I got a adjustable clutch quadrant and dialed in some pressure, no problem!
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Oct 10, 2004
  • Oct 10, 2004
i just orderd a FRP HD clutch kit but in the reviews i heard that the TO bearing is junk, should i buy a new one instead of using the one in the kit?
94GTStang
1,631
Oklahoma City
Oct 11, 2004
  • Oct 11, 2004
If you can, go ahead and buy a better one. Ford just has a bad supplier for their T/O.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
