Thunderbird Steering Wheel
  • Thread starter Thread starter nickm347
  • Start date Start date Feb 11, 2009
N
nickm347
160
  • Feb 11, 2009
bnickel
5,640
lubbock, texas
Feb 11, 2009
  • Feb 11, 2009
nickm347 said:
The steering wheel in my '73 Mustang is old and cracked. I found a good steering wheel out of a '72 Thunderbird in good shape. If I just replace the horn pads, will this be close to an original style? I didnt get a chance to measure the T-bird wheel, but it looks very similar. Thanks
well you didn't say whether you had a standard 2 spoked wheel or a 3 spoke rim blow or even a 2 spoke rim blow wheels which was available about that time as well.
assuming same style to same style you should be ok.
N
nickm347
160
  • Feb 11, 2009
bnickel
5,640
lubbock, texas
Feb 12, 2009
  • Feb 12, 2009
nickm347 said:
Thanks. Sorry I forgot there were multiple styles. It is the 2 spoke wheel. What is the difference between the 2 spoke and 2 spoke rim blow?
the 2 spoke rim blow wheel is just like the 3 poke rim blow in that the horn is activated through a little rubber ring around the inside circumference of the rim, thus rim-blow, the standard 2 spoke wheel has a horn button in the center of the wheel that the rim blow does not.
also the t-bird wheel likely has cruise control and it will have the controls in the wheel center pad, regardless of whether or not it has the rim blow function
C
Calponycarsmike
71
Southern California
Feb 13, 2009
  • Feb 13, 2009
It should bolt on no problem.
H
Steering whine
  • healy1963
  • May 9, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 10, 2026
gkomo
T
Want to Buy (WTB): 1980 Fairmont/Mustang structural dash hull.
  • TimSA
  • Jun 17, 2026
  • Want to Buy
Want to Buy Jun 17, 2026
83 steering wheel question
  • x_man586
  • Jun 3, 2025
Fox 5.0 Mustang Tech Jun 4, 2025
x_man586
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
D
Power steering to rack and pinion bolt
  • Demigxd
  • May 21, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 21, 2026
Demigxd
D
