Engine Ticking/Squealing Noise
So over the past day or two, I've had a weird ticking noise coming from the distributor/water pump area. Its gotten to be more of squeal now, especially at higher rpms. I mean, its loud. I can easily hear it driving around over top of the exhaust and music... and its getting worse. I'm thinking its the water pump but I'd like to get another opinion. Or am I about to blow a rod? LOL. BTW, not getting any fluid out of the weep hole. There is some leaking around the bottom part of the gasket. Cars also been getting pretty hot the past few months. Heres a few videos of the sound.
How it originally started out...
View: https://youtu.be/lHcw2p2GoGI
What its developed into...
View: https://youtu.be/uhlgrVg76MU
Thanks!
See if the fan moves up/down/sideways (with the engine off of course :doh: ) if it has any movement stop driving it, the water pump bearing is about to come apart and when it does you will loose the radiator too.
Welp. Its not the water pump. Still doing it with a new one on there. Seems to be coming from the left front of the engine. Developed into a new kinda sound and its gotten extremely loud. Completely random though. Sometimes it'll be quiet, other it'll get bad. The smog pump does make a ticking sound when spun by hand. Could that be the culprit? Heres another video.
View: https://youtu.be/LZVFWX3YBLI
Thanks again!
Gonna sound crazy but snatch the smog pump off. Take a drill and adapt whatever you need to to spin the pulley fast. I make all kinds of gadgets so that's just what I would do. OR....cut you a section of small tubing. Stick one end in your ear and use the other like a stethoscope to find the noise. Second option is the easiest.
Reactions: General karthief
