Time to mod again. Need advice
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date Dec 10, 2011
Which one?
  • Option 1
    Votes: 0 0.0%
  • Option 2
    Votes: 2 100.0%
  • Total voters
D
Dec 10, 2011
  • Dec 10, 2011
Alrght so I was finally awarded my last insurance settlement from the car accident I had about 2 years ago (took them long enough). However, I'm pretty deadlocked on what route I want to take.....
Option 1:
-MHS or HiTech stg. 2 cams
-MHS reground/clearanced valves
-MHS 600 lift stg. 2 springs
Option 2:
-shocks/struts
-LCA's
-complete bushing upgrade
-TB/plenum
-UDP's
-slotted/drilled rotors w/ SS lines
Help me out.
Kornnut
1,999
48
108
Tulsa
Dec 10, 2011
  • Dec 10, 2011
What about the install cost? How much money are we playing with here?
txredgt
1,343
33
69
Dec 10, 2011
  • Dec 10, 2011
Tough call, how many miles on the car and how bad is the suspension? I know you already have the H&R's so I would go that route to finish that off. I think the next round of mods for me personally will be cams and the lca's with bigger meats in the rear. I'm getting a bonus check and my unused pto hours at time and a half so I will have good money for that in April. I still say suspension but cams are nice. What's the end goals for the car idk if I have seen you say that yet.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Dec 10, 2011
  • Dec 10, 2011
Cams AND lower control arms....you wont hook without them if you get cams....just don't forget to factor in the cost of a tune to go along with the cams
D
Dec 10, 2011
  • Dec 10, 2011
Install cost isn't a problem. The guy who helps me with all my installs is a close family friend and is always negotiable with price and payment
Im getting around $3500 but only want to play with around $2k.
Yea I have that in mind. If worst comes to worst I'll just go a little while without a tune.
I've got 75K on it right now. It rides rougher than I would like which is why I want to overhaul the suspension......but the lure of bumpsticks is soooo enticing lol
D
Dec 10, 2011
  • Dec 10, 2011
I think that I've talked to you before about your HiTechs but Im drawing a blank......
What went into your install (springs, valves, degreeing, etc)? Are/have you having/had any issues with them such as PTV? Was there any big difference through the midrange?
Im debating between the HiTech 2's and MHS stg 2P's
Kornnut
1,999
48
108
Tulsa
Dec 10, 2011
  • Dec 10, 2011
Option 2 + MM phb.
midnightdriver
443
Northern California
Dec 11, 2011
  • Dec 11, 2011
Say it with me, blower.........blower...............blower
You can piece a centri kit for close to 2, and it will definitely beat cams any day of the week.
Stumbaugh
903
Russellville, Ar
Dec 11, 2011
  • Dec 11, 2011
Dont forget about a converter.
D
Dec 11, 2011
#10
  • Dec 11, 2011
  • #10
Is that in relation to cams or just in general?
BTW, briefly looking at TC's......DAMN they're expensive. Is it really worth it?
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Dec 11, 2011
#11
  • Dec 11, 2011
  • #11
I ran hitechs for a bit without springs and had no issues with ptv...I now have new valve train to back it up because I rev to 6,8000 and I don't trust stock springs after 6,500... one thing to consider is hitechs don't lope crazy but they make excellent power...mhs lopes nice and make power so if you want a cam that's powerful and noticeable go with mhs....
Ill post bids in a bit on how mine sound....it took me a bit to work out getting in to lope like a stage 2 cam should lope
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Dec 11, 2011
#12
  • Dec 11, 2011
  • #12
Oh, my friend has an auto 02 with hitechs and he's been running stock springs with them for about 15k miles so far and has been ok....
And fwiw I went 700 miles cammed and without a tune and was perfectly fine..... BUT I never took it over 3 k
slayerripkdc
1,341
brewster ny
Dec 11, 2011
#13
  • Dec 11, 2011
  • #13
Night SHIFTER you rev to 6800rpm? What kind of heads are you running?
Dark04GT
758
62
59
NC
Dec 11, 2011
#14
  • Dec 11, 2011
  • #14
I've been running my hitechs for about 7500 miles on stock springs without any problems. They are degreed. In retrospect I wish I would have upgraded my springs and got my valves ground down- now it will have to be a future project. (I haven't had any problems though). The hitechs have a very mild lope but a plus is my CAI makes significantly more of an air sucking sound.... everyone thinks my mustang is blown.
I'm happy with my hitechs but like with every mod eventually you want more- getting a blower is always the right answer.... I wish I would have used the money towards a blower instead. Also with the UDP... I wish I didn't get them- I noticed SOP gains but if/when I get a blower I will either have to swap them out or do pulley math to get it right / be concerned because water pump etc. is spinning 25% slower.
To answer your original question I would like other people have said do a mix if install costs are not a big problem-
Option 3:
-shocks/struts
-Steeda bumpsteer kit
-Alignment to MM specs
-Hitech stage 2's (if staying NA)(degreed with springs and ground valves)or MHS stage 2 cams (blower cams now are not a bad idea for future planning)
-24lb or greater injectors (blower in the future?... 39/42's) (another failure to look forward on my part)
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Dec 11, 2011
#15
  • Dec 11, 2011
  • #15
Modular powerhouse stage 2's from before they closed up...full comp valvetrain
slayerripkdc
1,341
brewster ny
Dec 11, 2011
#16
  • Dec 11, 2011
  • #16
I would finish up the suspension.... Don't mean to steal the thread but how much faster is your Evo 10 in a straight line compared to your full bolt on, cam, heads 2v? I Raced my buddies from work from a 3rd gear roll at 3krpm and surprisingly he only pulled about a fender. I don't think he can drive lol.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Dec 11, 2011
#17
  • Dec 11, 2011
  • #17
In a straight line they're about equal because I don't have rear lower control arms on the mustang so it just spins through 1st... from a roll id be maybe a car length ahead....cornering the evo would stomp my mustang hands down...
The thin about the evo is it comes built with a 2 step rev limiter to get it out of the hole like a rocket...so if im staged and I let the clutch out just a tad and it activates the 2 step and holds the rev limiter at 5k...then all I do is slip the clutch and it launches like a rocket...
The mustang should be faster in a straight line than the evo but I havnt been able to test it yet...the gearing in the evo is crazy tight though so in 5th im rolling about 3k and starttin to get into boost and if I nail it it pulls like the mustang pulls in 2nd... I know this cause some guy in an srt8 challenger was trying g to mess with me and I walked him in 5th gear
After a few goodies from ams get here then the evo will be faster in a straight line than the mustang
Stumbaugh
903
Russellville, Ar
Dec 11, 2011
#18
  • Dec 11, 2011
  • #18
A converter is 100% worth it. I would put a bigger converter in before I did cams. If you have an automatic and are looking to put aftermarket cams in it, then you are going to need a bigger stall.
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
D
help me spend some $$
  • DerekStangGT
  • Jun 1, 2008
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Jun 3, 2008
DerekStangGT
D
  • Locked
FS: 1993 LX 5.0 347 stroker reef blue/black int.
  • 87nitemare
  • Mar 9, 2010
19K
Fox Body Mustangs For Sale (1979-93) May 19, 2010
87nitemare
