  • SN95 4.6L Mustang Tech
Time to replace PCV?
  • Thread starter Thread starter Silvergto2
  • Start date Start date Feb 27, 2006
Silvergto2
179
UTAH
Feb 27, 2006
  • Feb 27, 2006
I have 65k miles on my car currently, and noticed recently that there is a little bit of oil pooling up where the PCV Valve is. I am going to replace the valve on Saturday, but want to get some opinions to see if that is all I should do. Also how do I remove it? I tried to twist, pull, etc, but it didn't seem to want to come out.
sgarlic
3,085
Feb 27, 2006
  • Feb 27, 2006
Remove your air tube for more room to work.. from previous threads I just checked, looks like the 02 is the twist in type. Be sure to use a Motorcraft replacement, not a POS parts store one.
Motorcraft's site says EV261 if you have twist in style PCV valve, or EV253 if not.
Silvergto2
179
UTAH
Feb 27, 2006
  • Feb 27, 2006
Thanks for the reply....I'll just keep trying to twist it out. I'll make sure to get the Motorcraft part. Does replacing the PCV Valve sound like what I need to do then to fix that pooling of oil problem? Its not alot of oil, but its enough to make me worry abit.
CobraM23
266
Johnson City, TN
Feb 27, 2006
  • Feb 27, 2006
If its stuck shut, it is your problem. Once you get it off, shake it and see if it rattles.
the98stang
2,408
Clovis, CA
Feb 27, 2006
  • Feb 27, 2006
Even if it's not the PCV, it wouldn't hurt to replace it....
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 27, 2006
  • Feb 27, 2006
Yeah, it is not expensive just replace it...
sgarlic
3,085
Feb 27, 2006
  • Feb 27, 2006
Don't trust that shake method.. PCV's are so cheap and easy to replace that you may as well just replace it every other oil change or every few oil changes.. should help your oil pooling problem.
D
dallas2002GT
52
  • Feb 27, 2006
I had this same problem on my 02. I had to replace the stock hose that connects to the pcv going to the throttle body.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Feb 27, 2006
  • Feb 27, 2006
Ya ithink they are like 5bucks. if in question, replace it
dustang50
132
Cleveland, OH
Feb 27, 2006
#10
  • Feb 27, 2006
  • #10
I just put on a new tb & plenum this weekend & found a coating of oil on the insides of the old plenum. Guess I'm changing mine, too!
40th GT
916
Lawrenceville, GA
Feb 27, 2006
#11
  • Feb 27, 2006
  • #11
Where's the PCV valve located?
D
dallas2002GT
52
#12
  • Feb 27, 2006
  • #12
Up under about the middle of you air intake.
sgarlic
3,085
Feb 27, 2006
#13
  • Feb 27, 2006
  • #13
Changing your PCV valve won't cure that. The PCV allows air (with oil in it) from the crankcase to be circulated back to the intake plenum.. You need to make an air/oil separator that sits within the hose leading from the crankcase to the plenum. The separator will help to filter the oil out before it returns to the plenum.
http://www.sgarlic.com/04stang/separator.html
C
cooter_11
138
GA
Feb 27, 2006
#14
  • Feb 27, 2006
  • #14
It's located on the passenger side cam cover right in the middle, underneath your air intake tube. It should be a little plastic thingy with a hose coming out from it.
USMstang
114
Mississippi Gulf Coast
Feb 27, 2006
#15
  • Feb 27, 2006
  • #15
Mine was about $25 and I had to eat a can of spinach to get that sucker off. Look at the new one real good to see what you're dealing with and then get a big breath and picture it coming off. It will.
dustang50
132
Cleveland, OH
Feb 27, 2006
#16
  • Feb 27, 2006
  • #16
Got it. Thanks!
Why would Ford make it like that? Why wouldn't they filter out the oil before it goes into the plenum?
R
Red66GT
214
Simi Valley, CA
Feb 28, 2006
#17
  • Feb 28, 2006
  • #17
Whats the differnce between a Heated and a Non Heated PCV valve? (for the bullitt)
evolucion311
236
May 4, 2009
#18
  • May 4, 2009
  • #18
Ditto. After about a year, the NEW hose started to collapse. It seems the oil and heat softened it. My solution was to get a plumbing fitting about 3/8" in diameter from home depot. I jammed it inside of the hose to keep it from collapsing.
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
