I've been reading up on ignitions, and find myself wondering some things.
For engines with distributors, when you set mechanical advance, everywhere I've read says to have it all in around 2500 - 3000 rpm. Is that just because it isn't reasonable to time it with the engine at 5000, or 6000 rpm or is it because the motor needs that much advance at 3000?
I ask because if it needs that much at 3000, surely it would be better to put more timing on at higher rpm, say by using a bigger arm and heavier springs in a distributor setup.
For discussion, the following motor is a 302 with EFI and EDIS.
I'm trying to work out what would be best to plot in an EFI spark table. Is it best to just have (for example) 34 degrees from 3000 up to max, or make it gradual? I do mean mechanical only for this.
As for load-based timing, (vacuum advance) if you are at idle, and punch the throttle to 100%, do you want to advance the timing immediately or leave it at 8 degrees or whatever idle advance is set at?
What about if you are idling and you slap on 1/2 throttle? How much advance?
I've read that manifold vacuum advance is good for off idle power and ported was used for stricter pollution control, more after-burning in the exhaust whilst idling. Does this mean more idle timing would be better? Note: I don't mean more initial timing, (which advances the whole curve) just more idle.
Anyways, the first questions are the most important, they will help me answer the last questions, but discussion about them is welcome.
I look forward to discussion.
