Timing Cover gasket question
  • Thread starter Thread starter RAYMOND259
  • Start date Start date Apr 27, 2011
R
RAYMOND259
56
  • Apr 27, 2011
I replace my cam for a different one,I have a felpro one piece oil pan gasket.do I need to cut the end off it have the metal in the gasket?If I do how u guys cut it with?Thanks
50lxtacy
  • Apr 27, 2011
I had to pull my timing chain cover a few times with the same gasket and I didn't cut it. i just worked it on and havent had any leaks. It was a pain though
7upstang91
936
124
74
Florida
Apr 27, 2011
  • Apr 27, 2011
I had nothing but problems when I cut my gasket. They will have you replace the gasket with two cork pieces if I remember correctly. Sounds like you just replaced the oil pan gasket. To be honest a little RTV in that area of the pan and you should be fine. The gasket you have will still work, assuming the oil pan gasket is a newer one.
I justed a dremel (sp?) when I cut my gasket. IF you are going to cut the metal gasket, to replace the corners with those stupid cork pieces, IMO I wouldn't do it. My car leaked still, after I added those. I wish I hadn't cut my metal oil pan gasket.
R
RAYMOND259
56
  • Apr 27, 2011
Thanks u.I will leave it on
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
