You're probably getting an issue with the computer relearning the timing. If you time the car to run on the spray, it's going to run worse on motor. Optimum is to get an automatic timing retard like an MSD box or something.
Kurt
loosing 2* from the stock 10* should not in any way shape or form result in popping or backfiring in the intake. The computer does not relearn timing...it expects 10* as the starting point and goes from there depending on load/idle tables there is no learning end of timing like the KAMFR for fuel on our cars.
One other thing that can cause this if you took the spout out is that the HB is spun on its rubber insert. Is the HB the stock or factory replacement unit? It is a common issue and will cause your timing to be off. Unless you pulled the dizzy out I would look at the HB next and see if it has spun.
