Timing Problems
  • Thread starter Thread starter TheSlowLX
  • Start date Start date Nov 12, 2005
T
TheSlowLX
44
  • Nov 12, 2005
Seems like everytime I try to advance my timing (12-16*), my car starts surging like crazy. Right now my timing is set at 10* and the car feels alright, but I want a bit more of a kick to it. I do take the spout out when I check the timing and do everything right. Once I put the spout back in, and put the car in Drive(AOD), car starts surging and dies on me. Any suggestions as to what is happening?
HISSIN50
34
129
Nov 12, 2005
  • Nov 12, 2005
Is the idle raising appreciably from the timing advance? The puter might be trying to knock the idle back down to spec (causing a surge) if so.
Good luck.
T
TheSlowLX
44
  • Nov 12, 2005
Idle seems to stay put when I advance the timing. Just starts surging like crazy and dies. But when timing is at 10* or less, car acts fine.
88GTtom
198
Woodbridge NJ
Nov 12, 2005
  • Nov 12, 2005
advancing your timimg should raise your overall idle. what does it go to after you bump the timing? maybe after bumping the timing, you should lower your idle a little bit, turning the screw( next to the throttle linkage on the throttle body) counter clock wise. dont forget to disconnect the IAC before you set the idle. also, dont forget to reset your tps sensor if you go that route. should help out some. give it a try. good luck
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
