timing problems
stevesLX
373
cincinnati
I think I have some timing issues going on also. The way my balancer is set up is I have the the following marks going from left to right if you are looking at it to set the timing: 10 C 0 T 10 20 30 40.
I have my timing set at 14 with spout out. Its basically set between the 10 and the 20 marks. I guess this is before TDC I am not sure. I know if I turn my distributor to the left like towards the altenator it smooths out but if I move it to the right towars the battery it gets really rough. But right now the car just doesn't act right all the time. At times you can floor it and it just doesn't have any power it lags but then it will take off on you at other times. It seems like its differen't from one traffic light to the next. The other thing it will do from time to time is if you stomp on it from the get go it will run half way decent but if you drive normal and then go to stomp on it it will lack power sometimes. You have to let off the pedal and then stomp it again. Any ideas as to whats going on here and am I setting my timing right?
any ideas as to what it could be. My motor is pretty much stock w/ the exception of 24# injectors 65CFM MAF and a Edelbrock 5.0 performer intake. It also has a 75mm BBK throttle body and spacer. I have been told that TB is to big for the set up and that I also dont need that big spacer on there either. This was all here when I bought the car. It also has a 303F cam. I am new to all this stuff.
I'd give the timing one more check. If it's too retarded, it will bog like that. Not to offend, but I have to ask:
When you set the timing, you had the SPOUT connector removed? Otherwise, you are running real retarded.
For diagnostics, I will twist the dizzy (SPOUT installed since no timing gun is being used) till the car runs better, ignoring the marks on the balancer (a spun balancer makes for a poor point of reference anyhow).
WHen I find the sweet spot performance wise, I check timing just to see where I have it.
EDIT: If you use this method, be sure to keep an ear out for detonation (as should be done anytime timing is advanced).
Good luck.
O.K. yes I had the spout out and I always hear that term of detonation what exactly does detonation sound like? What kinda noise am I listening for? It idles pretty rough you can definitely hear it miss. And when you drive it almost feels like it loading up at times and when you stomp it and it just has no power but at other times it runs like a champ:bang:
Steve,
Have you checked for codes yet? Is your check engine light on, or does it come on sometimes? You can have stored codes without the CEL being on.
You can buy a code scanner for about $30 at auto parts stores, or you can do the free method. Do a search for "codes", and find jrichkers post detailing how to pull codes for free. It's pretty simple.
Jeff
I took the car somewhere awhile back and they struggled with it for a whole day trying to get codes out of it. My check engine light is disconnected. I dont even know where the wiring is for it to even try to hiik it back up. The guys before I owned it hacked it.
Steve, is the self test connector still in place under the hood (and hopefully unmolested)? It will be a trapezoidal connector in the back driver's side corner of the engine compartment. If it's okay, you can use a reader like Jeff noted or even a test light (SD cars dont have a functional CEL, so they have to use one of these other two methods. You can do the same).
Detonation sounds like marbles being agitated in a coffee can, and as it worsens, it sounds like marbles in a glass jar.
Good luck.
Yes I actually have the big connector itself and 2 single connectors on the drivers side corner. They are all in the same harness. I have a volt meter with the needle. Which one of those single conectors do I want to jumper to or probe.
Be real careful when pulling codes. IIRC, there is a black colored single-wire connector next to the single grey-colored one. The black wire has 12 volts going through it!
Anyhow, see Jrichker's post for code retrieval. Also, if you have a repair manual, the emissions chapter should have pretty detailed instructions.
Good luck.
