Try setting the initial timing (with a light) with the spout out at 14-16 degrees btdc. Put 93 octane in it. Listen for ping. If you're not getting any, then cut back to 89 octane. If still no ping, cut back to 87. Alternatively, if you're getting ping and don't want to or can't afford 93 octane, ease the timing back in 2 degree increments until the ping goes away. Most folks feel better throttle response and part throttle performance, and slightly better fuel mileage with this change alone. The downside is a warmer running engine (not an issue if your cooling system is up to par) and worse emissions.
