  • 1994 - 1995 Specific Tech
Timing question
  • Thread starter Thread starter dlaul01
  • Start date Start date Apr 18, 2007
dlaul01
169
  • Apr 18, 2007
I searched and could not find my answer ok .. my buddy recently put a pip sensor in my car he said that my timing will be off a little it pinged a little bit but kind of went away. So i went and got my car timed today by a buddy and now he put it where it should be and its pinging bad when i get on it. Does it have to reset its self or did he just not adjust it right. I know he knows what hes doing he said it will eventually stop?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Apr 18, 2007
  • Apr 18, 2007
You have to pull the .... umm. I cant remeber what it called. But you have to unplug it to set the base timing. Its a little gray plug on the passenger side fender around the intake tube.
The Green GT
1,269
Louisiana
Apr 18, 2007
  • Apr 18, 2007
SPOUT CONNECTOR
http://www.muscularmustangs.com/timing.php
dlaul01
169
  • Apr 18, 2007
He did that
The Green GT
1,269
Louisiana
Apr 18, 2007
  • Apr 18, 2007
Did he change the distributor when he changed the PIP? Or even take it out.
HISSIN50
34
129
Apr 18, 2007
  • Apr 18, 2007
And did anyone check the timing before the dizzy was pulled for the PIP replacement? This is always a good idea, in case the timing was set at 6 or 8* already, or the balancer's outer ring has slid (effectively making the timing marks useless).
Also ensure that your advance knob is set to zero if you use a dialback timing light.
Listen to what you hear above and beyond all else. If you hear pinging, back that timing down till you dont. That is ALL that matters - setting timing with a light just gives us a starting point and point-of-reference to share with other members.
Good luck.
dlaul01
169
  • Apr 18, 2007
Is it true though about the knock sensor or something has to reset its self
The Green GT
1,269
Louisiana
Apr 18, 2007
  • Apr 18, 2007
We dont have knocks sensors IIRC.
HISSIN50
34
129
Apr 18, 2007
  • Apr 18, 2007
Eric's right, and nothing with the global spark is adaptable.
dlaul01
169
#10
  • Apr 18, 2007
  • #10
Im going to have to have it retimed then by someone who knows what there doing. Then i have to fix a ground wire or something causing my cluster to mess up bad. Long day tomarrow
The Green GT
1,269
Louisiana
Apr 18, 2007
#11
  • Apr 18, 2007
  • #11
If the distributor was pulled, maybe he put it in one tooth off. Its a possibility.
OrangeMustangGt
1,976
Cape Cod, MA
Apr 18, 2007
#12
  • Apr 18, 2007
  • #12
A tooth off dosen't matter.....you can turn it to compensate....
What I do, is Set the timing to 14 btdc then take it out for a nice warm WOT run, and if i hear timing i back it off 2 degrees and so on till i get NO KNOCK...
you cant just time it and leave it if you want peak power.......if you just want factory setting get it to 10 btdc and be happy.
HISSIN50
34
129
Apr 18, 2007
#13
  • Apr 18, 2007
  • #13
Kyle is right - the one tooth off thing is a bit of a misnomer. The only time anyone is one tooth off is if something is physically keeping the dizzy from turning further to get into time.
Timing it is real simple - have some confidence in yourself. As we've said, just dial the timing down a hair for right now - what you hear is all that matters. If you retard the timing too far, an indication is that your hot, no load idle will be real low. I'd rather be real retarded (well, I already am ) than a little too far advanced.
Good luck.
dlaul01
169
#14
  • Apr 19, 2007
  • #14
Thanks guys your a lot of help so ill make sure its set to 10 and try to see if it will stop pinging i dont know what he put it on yesterday as soon as i get off work i will solve this problem i will update you guys THANKS !!!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 19, 2007
#15
  • Apr 19, 2007
  • #15
The whole ... "One Tooth Off" thing has always been a sore spot for me
Some say ... "That is a bunch of internet myth"
and
Others say ... "Of course it can be a tooth off"
Me ... Myself ... and I ... We fall in that last camp of folk
I have always seen it from an original reference point of installation
so
I've always seen both camps of peeps thoughts to be valid
I only posted here to once again show ... JT's just Plain Ole Good :Word:
I mean ... Look at those words of wisdom in the quote
He tells the truth
He tells the truth that represents both sides of this issue
and
He tells it all ... Simply in just a few easy to understand words
Now me on the other hand ... I would have written a page to do it
JT ... I'm glad we got you here my friend
Grady
dlaul01
169
#16
  • Apr 19, 2007
  • #16
he said he set it to 5 degrees advanced shouldnt i be at 10?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 19, 2007
#17
  • Apr 19, 2007
  • #17
yeah, 10* before top dead center. Maybe he set it at 10* after top dead center.
On the factory balancer, there is 30 llllll 20 lllllll 10 llllllll 0 lllllllll 10. If you set it to the last 10, that is 10*atdc. You want it on the bold 10
Scott
dlaul01
169
#18
  • Apr 20, 2007
  • #18
OK and if i set it to that and it still dont work i want to back it up or go forward?
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
P
New here
  • PortCity
  • Jun 9, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 9, 2026
AeroCoupe
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
