  • 1994 - 1995 Specific Tech
timing question
  • Thread starter Thread starter mustang1994gt50
  • Start date Start date Nov 26, 2008
M
mustang1994gt50
  • Nov 26, 2008
hi new here i just bumped up timing but now it seems to have charging problems the amp gauge goes up and down when i turn on the heater and radio or lights it didnt do it before any suggestions
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 26, 2008
  • Nov 26, 2008
id say its a fluke , changing timing should have no affect on the charging system
R
riored94cobra
Indy, IN
Nov 26, 2008
  • Nov 26, 2008
udp?
toyman
1,944
54
79
Vernon BC
Nov 26, 2008
  • Nov 26, 2008
Changing the timing won't have any affect on charging. I assume that you mean voltage drops (not amps) when you turn on the lights, heater and radio. If you are talking about this at idle, that's pretty normal. The gauge should though show increased volts as the rpm's increase from idle.
HISSIN50
34
129
Nov 27, 2008
  • Nov 27, 2008
Did you use a timing light or just wing it? If you accidentally retarded timing or forgot to replace the SPOUT connector, the idle will be low and very finicky with regard to alternator output.
hollywoodstang
1,095
Nov 27, 2008
  • Nov 27, 2008
How do you just "wing" the timing?
HISSIN50
34
129
Nov 27, 2008
  • Nov 27, 2008
Though I'm sure it's not the case here, it's surprising how many people just turn the dizzy a little and don't check the actual timing with a timing light.
M
mustang1994gt50
  • Nov 27, 2008
well i was using a timing light and i loosened the bolt and bumped the dizzy but then couldnt see the freakin timing marks then the stupid timing light clip on the spark plug popped off and broke talk about bad luck i guess i will just buy new one and check and the stupid timing marks on these cars are a pita too see my sixty six is right there
HISSIN50
34
129
Nov 27, 2008
  • Nov 27, 2008
Is the SPOUT connector installed?
I use a silver sharpie to mark the balancer whereever I want to set the timing (10, 12* etc).
Good luck.
M
mustang1994gt50
#10
  • Nov 27, 2008
  • #10
yeah spout was disconnected then put back in i will mark then thanks stangers much appreciated
C
cbarr300
746
goose creek, SC
Nov 28, 2008
#11
  • Nov 28, 2008
  • #11
I'd have to agree with JT on this one. I believe you just got the timing slighty screwed up. Just reset the timing and retest. Take a silver marker as JT suggested or some white out and mark 10* BTDC (very important it's before top dead center and not after top dead center).
M
mustang1994gt50
#12
  • Nov 28, 2008
  • #12
thanks guys got new light yeah it was way off it was easier just to remove the fluid overflow so the light could get in there and i marked with pen even the guys mark i bought it off of was way off he had nail polish on dizzy runs great now thanks peace homies
Stevejr
63
Humboldt Tn
Dec 19, 2008
#13
  • Dec 19, 2008
  • #13
Can ya bump up the timing on a 95 I thought the computer would set it back . If so what do ya recommend Mines still pretty much a stock Cobra.
HISSIN50
34
129
Dec 19, 2008
#14
  • Dec 19, 2008
  • #14
Yes you can bump it. The EEC doesnt change global spark if you make a timing change.
Stevejr
63
Humboldt Tn
Dec 19, 2008
#15
  • Dec 19, 2008
  • #15
If im not mistakin it is set a 10 what do ya recommend This is a daily driver.
Stevejr
63
Humboldt Tn
Dec 21, 2008
#16
  • Dec 21, 2008
  • #16
Got it thanks.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 23, 2008
#17
  • Dec 23, 2008
  • #17
At least 14 degrees of timing.
Kurt
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
