  • SN95 4.6L Mustang Tech
timing
  • Thread starter Thread starter Torinalth
  • Start date Start date Apr 4, 2005
T
Torinalth
952
Clayton NC
Apr 4, 2005
  • Apr 4, 2005
hey guys,
I'll be getting my TA in couple weeks and wanted to get some background on what is the best way to determine what timing to run. should i just start at 10* and go up by one till i hear it ping then back it off one? just curious to see what to do. also, the TA is a must as the only way to adjust correct? i know the preditor has the ability to change the timing settings, but can it actually do anything on its own without the TA?
Torinalth
propellerhead
1,541
"but what's with the but shots?"
Apr 4, 2005
  • Apr 4, 2005
Yes.
Yes. The TA you're getting does it mechanically. The Predator does it electronically, via the Engine Computer. In fact, the Predator only alters timing at WOT, and it adds timing proportionally. It adds a percentage of base timing. So if you set the Predator to +10% and the normal timing at a specific RPM and load is 5*, you'll get 5.5* -- a difference of 0.5 degrees. If the normal timing at another RPM/load is 33*, you'll get 36.5* -- a difference of 3.5 degrees. With a mechanical timing adjuster, you'll get a fixed amount added to all points in the timing table, WOT and part throttle.
T
Torinalth
952
Clayton NC
Apr 4, 2005
  • Apr 4, 2005
wow, very informative.... i suppose the question would be then, do they work well in tandem, or will it not make a difference considering the mechanical TA. or... would you be best doing something of the following:
max out your TA at say 15*, back it off to 13 for every day driving, then use the preditor to max it say 15% for WOT....
interesting concept to be sure. thanks for the info
Torinalth
jstreet0204
939
Winston Salem, NC
Apr 4, 2005
  • Apr 4, 2005
Torinalth
You don't want to run them together. The TA is actually more of a way of fooling the EEC, by changing the position of the crank sensor. Both work well, you just need to stick to one way or the other.
StangPro
441
Roseville, MI
Apr 4, 2005
  • Apr 4, 2005
If you're looking at a tuner, just do that. It does the same job as the TA and will save you cash over buying both.
With a tuner, you don't need the TA.
CanadaStang
2,093
Mb
Apr 4, 2005
  • Apr 4, 2005
what he said^
T
Torinalth
952
Clayton NC
Apr 4, 2005
  • Apr 4, 2005
I'm, getting a killer deal for the TA/UD pully combo so i dont think i can pass that up. when i do get the preditor i'll pull off the TA and sell it then and just run the pred, but i dont forsee the pred till another 6 months at the earliest.
Torinalth
my_03GT
186
DE
Apr 4, 2005
  • Apr 4, 2005
I ran the T/A and underdrive pulley combo until my KB. Your timing depends on what gas you have(octane). If you can get 93 or 94, you can set it to 16 or so, if you can only get 91, set it to 14. I know by experience. I was stationed up north and had 94, I am now in So Cal so I can only get 91.
M
Mustangl3
242
willow grove, pa
Apr 4, 2005
  • Apr 4, 2005
so if you only conider adjusting timing, the TA is better than the predator because it adjusts timing a part throttle as well as WOT
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
