First: Each application is different. A stock N/A car can have up to 14 degrees of timing where as a S/C car is only going to use 10 degrees.
I think the total timing on the Mustang is 36 degrees. There was a thread about it less than 1 month ago.
To advance, loosen the distributor hold down. Rotate clockwise (to advance) and tighten the hold down. Drive the car easy to listen for detonation. If no detonation is heard, keep going up and then back it off once you reach the limit.
14 degrees is about all an iron headed motor likes. Aluminum heads can safely handle a little more.
Edit: I also forgot to mention that with large amounts of advance, you will need to run better gas. So decide on what octane gas you want to run. Fill up the tank and then start advancing.
