Tire pressure
  • Thread starter Thread starter 5.0TailPipeHump
  • Start date Start date Jan 19, 2007
5.0TailPipeHump
153
Jan 19, 2007
  • Jan 19, 2007
Hey ppl just wondering what kinda pressure you put in your tires for that good take off.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jan 19, 2007
  • Jan 19, 2007
Street tires or slicks/drag radials? A lot of people think letting air out of street tires helps but it just distorts the "footprint"....i've found that it's best to just air them up to the recommended pressure and do a good burnout, stay out of the water box at the track and spin'em untill they squeel and you'll be about as good as it gets.
1Bad88notch
62
Leesburg,FL
Jan 19, 2007
  • Jan 19, 2007
I usually run 15 pds. in my drag radials.
NKau
1,346
Jefferson, WI
Jan 19, 2007
  • Jan 19, 2007
What he said. With drag radials, you'll see guys run anywhere from 15-22 psi typically at the track.
93gtmustang
524
43
49
Jan 19, 2007
  • Jan 19, 2007
Below is from from Nitto Tires on correct air pressure to use with their drag radials.
For track use the pressure can be set to 20 PSI and adjusted accordingly to your preference, but never use the tire below 15 PSI.
We recommend to mark the wheel and tire (using paint or shoe polish) to monitor slipping between the tire and wheel. If the tire moves on the wheel (even a fraction of an inch), pressure should be increased.
After racing is concluded return the tire pressure to normal PSI for street use.
In our testing, we found for optimal performance, the surface temperature of the tire should be greater then 110 degrees Fahrenheit. Burn out time is dependent on track conditions in order for the tire to reach this optimal temperature. I hope this has answered your questions and I thank you for your business.
You can also increase air pressure on your front tires for less drag. I run 40psi on BFG G-Sports on the front when drag racing (44 max psi on this tire, check yours). 18 PSI on my Nitto drag radials on the rear.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 19, 2007
  • Jan 19, 2007
really lower the psi and do a burn out. see what the foot print looks like. once you have rubber on road right across you have it right.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 19, 2007
  • Jan 19, 2007
from my expierences. tire pressure has no affect on street tires and hardly any on my drag radials. you need the low air pressure when u have an actual wrinkle wall slick.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Spare tire orientation?
  • Bib36`
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
JD1964
A
87 GT - Low Fuel Pressure Problem
  • Asbury
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
