Tire Wear
  • Thread starter Thread starter Wayne K
  • Start date Start date Jul 24, 2012
W
Wayne K
61
  • Jul 24, 2012
My 2010 GT drives straight & smooth with no handling issues but it is scalloping the inside tread on the front tires. Other than toe adjustment I don't think there is camber or caster adjustments on these cars. Just wondering if others have had this problem and what the fix was if there is one. I rotate every 5000 miles and have 16000 on it now so all the tires have been on the front and all are scalloped. I now have the rumbling tire syndrome.
ct07gt
377
  • Jul 24, 2012
Scalloping is usually a toe issue. There is not really any caster adjustment that I am aware of. If you want more camber adjustment, I have the Steeda HD strut mounts and they have a degree of camber adjustment. I am at -1.5 degrees, mostly for autocross. The stock strut mounts are junk, they start making a popping noise when they fail. Mine fell into two pieces when I took them out to replace them.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 25, 2012
  • Jul 25, 2012
I agree... It's usually a toe issue, or lack of rotation issue. You can still drive straight, have no pulls, and steering wheel be perfectly straight and the toe be out quite a bit. Cross rotate the front tires to the rear (put RF on LR, LF on RR, rears straight up) and this will help wear the tires back smooth. Get the alignment checked and get a print out of the before and after so you can verify there was a problem... Not just the shop saying it was out.
Nick
claudermilk
62
Jul 26, 2012
  • Jul 26, 2012
If he has directional treads, they cannot be cross rotated. I would expect that they are; double check before doing this.
ct07gt
377
  • Jul 26, 2012
I don't think cross rotating them would help anyways, the only way to try to even them out is to dismount the tire from the rim and flip it, but it wouldn't work with directionals as you said.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 26, 2012
  • Jul 26, 2012
Agreed. If they are directional, you're pretty much screwed unless you wanna run your tires backwards for one rotation cycle.. Not advised.
streethorse
1,042
Dallas Texas
Jul 26, 2012
  • Jul 26, 2012
I ran some Kumho tires backward because of wear issues once for like 6 months
on my former 04 gt ... couldnt tell the difference on dry pavement.
But it never rains here.
R
Wow, Tire Issue on 2019
  • Rcdgl
  • Dec 30, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sunday at 4:29 PM
Rcdgl
R
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
