  • 1994 - 1995 Specific Tech
Tko strategy
  • Thread starter Thread starter miller92063
  • Start date Start date Oct 17, 2005
M
miller92063
253
Nebraska
Oct 17, 2005
  • Oct 17, 2005
I have a 1994 mustang gt with an aode. I am swapping it out for a tko-500.
What can I expect for problems during the swap?
I also have a problem somewhere in my drivetrain. under enitial load and also in reverse i have a really bad clunking/kinda grinding noise happening, any thoughts?
thank you
94-302-vert
1,947
NE CT
Oct 18, 2005
  • Oct 18, 2005
Why a TKO-500 not a TKO-600? I think if I were spending that kind of cash I would go with the 600 jsut since it is only short money more than the 500...
I know it does not answer your question so free bump for ya...
M
miller92063
253
Nebraska
Oct 18, 2005
  • Oct 18, 2005
I like the lower gear in the 500 and also the 600 is a 28 spline input shaft.
FORCED2DV8
458
Grand Rapids MI
Oct 19, 2005
  • Oct 19, 2005
You wil most likely have to make spacers out of washers or something similiar for the trans crossmember,and a little modification to it so it fits correctly. your loud clunking may be u joints/really worn rear end/or you front end a arm bushings are really worn along with lower ball joints will also make that sound, especially if you put in in gear with brake on, or under load, check u joint first though that would be easiest, push on drive shaft at the joint up and down to check for movement.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 19, 2005
  • Oct 19, 2005
Do a search....i made a thread along with many others about this very subject.
Index your bellhousing....if u dont know how, search about it. I crossed my fingers and hoped i would come out ok. I did my swap and had a vibration at 80mph on the freeway. The car isnt running so i have plenty of time to check over things but its best to do it in the beginning.
M
miller92063
253
Nebraska
Oct 22, 2005
  • Oct 22, 2005
bought new driveshaft last week , still makes noise!
4Jenna
4,326
AZ
Oct 23, 2005
  • Oct 23, 2005
you can get a 5th.64 in a tko600...lmao
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 23, 2005
  • Oct 23, 2005
You bought a whole new driveshaft just to try to fix that noise? I sure hope you still had the stock piece and not a aluminum one.
You should try to put it up on a hoist, start the car, and see if u can tell where its coming from. If its not the u-joints, then my next guess would be something in the rear end.
I think he's talking about 1st gear which stays similar to the stock t-5 at like 3.35 or something. Thats gonna be a pain later on down the line when he's making some good power and a 3.733, 4.10, or 4.30 in the back. 1st gear will be useless.
M
miller92063
253
Nebraska
Oct 23, 2005
  • Oct 23, 2005
i was going to buy an aluminum d/s anyway.
i put the car up on jack stands but it wouldn't make the noise.
it only makes the noise when it is in gear never does it when it is in neutral.
i just put 3.90's in the rear probly two months ago. began to make the noise one month ago one week after i went to the track.
D
dannydoo
195
Jan 15, 2006
#10
  • Jan 15, 2006
  • #10
That would be the wheel bearings then..Verry verry common!
BDAWK2002
139
Old Bridge N.J.
Jan 15, 2006
#11
  • Jan 15, 2006
  • #11
If your gonna go with a TKO you need a driveshaft for a 96-98 cobra and a driveshaft spacer.Also needa special bellhousing think it one for the cobra also.You must index the bellhousing.Taking mine back out now.
D
dannydoo
195
Jan 16, 2006
#12
  • Jan 16, 2006
  • #12
what? a 96/98 cobra driveshaft?
why is that?
He should be able to use any 5spd driveshaft from 93 and under.
And use the spacer still.
with a tko.
The 96-98 uses the same length as a 5spd 5.0 fox?
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jan 16, 2006
#13
  • Jan 16, 2006
  • #13
I think the 96-98 either already has the right yoke or its the right length. I forget though.
a driveshaft for a 5.0 will work fine with the right yoke and a spacer.
WhiteDevil
2,717
San Diego
Jan 16, 2006
#14
  • Jan 16, 2006
  • #14
I always thought this was a smarter move, because when people swap to T-5s and buy a new T5 its only like 300 more for a new TKO which will last a million times longer. If i can remember from my swap i needed
Bell Housing
Clutch Fork
TKO-500
Offset Transmount
31 Spline Yoke
Driveshaft Spacer
3qts GM Syncromesh
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
uh oh that sounds like $$$$$
  • *HOOFHEARTED*
  • Jan 17, 2025
1994 - 1995 Specific Tech Jan 18, 2025
*HOOFHEARTED*
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
