  • SN95 V6 Mustang Tech
to replace a fuel filter?
  • Thread starter Thread starter H8Eternal
  • Start date Start date Feb 16, 2004
H8Eternal
51
queens NY
Feb 16, 2004
  • Feb 16, 2004
Is It hard to change the fuel filter on a 2001 stang? & where Is It located, under the car right?
It has 22000. miles, so should It be a good Idea to change It?
Thanks.
GREENBIOCH
1,241
In an Igloo
Feb 16, 2004
  • Feb 16, 2004
No it isn't to hard to replace. It is behind the gas tank under the car. You need a fuel line/AC disconnect tool, like 10 bucks at local auto store, use the tool to disconnet fuel line from filter and put neww one in, the line is pressurized so be careful of fuel spraying out when you disconnect it. They say to depressureize the system before you do this I just wait a day then the pressure drops over time and isn't so bad. But there is another tool you can buy to depressureize it if you want, but isn't necessary. Just be careful of your eyes when doing this, were goggles or something. Fuel filter is like 10 to 15 bucks or so.
V
v6asian
29
southern california
Feb 17, 2004
  • Feb 17, 2004
expect some gasoline to leak ...
Gault
173
Peyton, CO
Feb 17, 2004
  • Feb 17, 2004
While it is never a "bad" idea to replace a fuel filter on an older car, if you have been the original owner, I am not sure I would replace at 22k. Other factors may apply like you may have big power adders that would require more fuel than a stock setup, but I would guess a well cared for car would not need a filter replaced until 100k or more.
Unless you run the tank low and are not picky about your gas, I don't think it would need replacing.
oogtdude
Banned
Jun 9, 2002
1,626
  • Feb 17, 2004
be carefull with the line diconnect tool..theres like little metal things that lock it in place..if u bend those your screwed..just push them in ..then pull line..dont fool around with the tool 2much
R
Ron Jeremy
747
Hollywood, California...I live next door to Jenna
Feb 17, 2004
  • Feb 17, 2004
Ford service rescommends that you replace the fuel filter at 30,000 miles. Every 30,000 miles. Not anytime less than that.
GREENBIOCH
1,241
In an Igloo
Feb 18, 2004
  • Feb 18, 2004
I replace mine yearly wether it needs it or not. Nothing wrong with over maintaing it, oil changes I do quite often as well. tranny fluid and coolant. I am overprotective. Sparkplugs and air filter cleaning quite regularly. Call me crazy.
98CobraClone
592
Ripley, Ohio
Feb 18, 2004
  • Feb 18, 2004
How many times have you seen Ford to be right? I mean, they went and damaged your perfect car.......
01White5spd
246
New Jersey
Feb 19, 2004
  • Feb 19, 2004
Too make sure the fuel system is depressurized you can shut the fuel pump with a switch in your trunk. It is on the left(drivers) side when you open the trunk. You'll see a hole in the trunk lining material and there is a plastic button, if you lift the button up using the slot that is there it will shut the fuel pump. Then try to start the car and it should either not start or start and stall in a second. Then to turn it back on just push the button back down.
H8Eternal
51
queens NY
Feb 20, 2004
#10
  • Feb 20, 2004
  • #10
thanks for all the help. but I agree with GreenBioch, I am very overprotective as well.
can't go wrong with that.
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
SN95 V6 Mustang Tech Mar 20, 2026
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Is this a fuel filter?
  • Dutch74
  • Oct 2, 2025
1974 - 1978 Mustang II Talk & Tech Oct 21, 2025
welder4956
