tomustang and other drag suspension guru's
blackfang
1,290
Richmond, Va
They'll fit, shouldn't be any different than adding fox stock springs on a sn-95, the only thing that would cause a slight problem is that the moroso springs are built around the weight of a fox body, that being less weight of the cobra but shouldn't be that noticable or not even at all
there is some drop wth the Bullitt springs, not much, maybe a 1/2" but you dont want tobe to low if your going to race the car as there wont be enuff spring for weight transferr, its tuff to get the best of both worlds.
Exactly.....lowering springs aren't the best choice at the strip. They rear springs are too stiff to allow the rear end to squat properly, and the front springs to stiff to allow enough rise in the front end to most effectively transfer the weight to the rear of the car.
When was the last time you saw a lowered car run fast at the track, compared to the other guy with the same parts under the hood and driving skill behind the wheel. :D
Steeda's drag springs are Eibachs. You'll have basically the same rear height with a raised front end if you keep all the coils on the springs. I'd still say keep the stockers. Or if anything, get front drag springs only.
